title: "Apollo Server integration | Grafana Cloud documentation"
description: "Learn about Apollo Server Grafana Cloud integration."
# Apollo Server integration for Grafana Cloud
Apollo Server is an open-source, spec-compliant GraphQL server that’s compatible with any GraphQL client, including Apollo Client. It’s the best way to build a production-ready, self-documenting GraphQL API that can use data from any source. This integration sends metrics to Grafana Cloud along with a useful default dashboard for visualization.
This integration includes 1 useful alert and 1 pre-built dashboard to help monitor and visualize Apollo Server metrics.
## Before you begin
This integration monitors an Apollo Server app that exposes metrics through [Apollo Prometheus Exporter](https://github.com/bfmatei/apollo-prometheus-exporter/).
To expose the metrics you need to instrument your Apollo server:
- Install prom-client and @bmatei/apollo-prometheus-exporter
![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```none
npm install prom-client @bmatei/apollo-prometheus-exporter
- Create an instance of the plugin:
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
const app = express();
const prometheusExporterPlugin = createPrometheusExporterPlugin({ app });
- Add the plugin to ApolloServer:
```javascript
const server = new ApolloServer({
  plugins: [prometheusExporterPlugin]
For full instructions and possible setup options please follow the [exporter guide](https://github.com/bfmatei/apollo-prometheus-exporter#usage).
## Install Apollo Server integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **Apollo Server** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send Apollo Server metrics to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboard and alert to your Grafana Cloud instance, and you can start monitoring your Apollo Server setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single Apollo Server instance running locally with default ports.
First, **manually** copy and append the following snippets into your alloy configuration file.
### Metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_integrations_apollo_server" {
	targets = [{
		__address__ = "localhost:4000",
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_apollo_server" {
	targets    = discovery.relabel.metrics_integrations_integrations_apollo_server.output
	job_name   = "integrations/apollo-server"
### Advanced mode
To instruct Grafana Alloy to scrape your Apollo Server instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced metrics snippets
```alloy
	targets = [{
	rule {
To monitor your Apollo Server instance, you must use a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to discover your Apollo Server Prometheus endpoint and apply appropriate labels, followed by a [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component to scrape it.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to your Apollo Server Prometheus metrics endpoint.
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Apollo Server instance.
If you have multiple Apollo Server servers to scrape, configure one `discovery.relabel` for each and scrape them by including each under `targets` within the `prometheus.scrape` component.
## Dashboards
The Apollo Server integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Apollo Server Overview
**Overview**
## Alerts
The Apollo Server integration includes the following useful alerts:
Expand table
| Alert            | Description                    |
| ApolloServerDown | Critical: Apollo Server not up |
## Metrics
The most important metrics provided by the Apollo Server integration, which are used on the pre-built dashboard and Prometheus alert, are as follows:
- apollo\_query\_duration\_bucket
- apollo\_query\_duration\_count
- apollo\_query\_duration\_sum
- apollo\_query\_failed
- apollo\_query\_field\_resolution\_duration\_count
- apollo\_query\_field\_resolution\_duration\_sum
- apollo\_query\_started
- apollo\_server\_starting
- nodejs\_external\_memory\_bytes
- nodejs\_heap\_size\_total\_bytes
- nodejs\_heap\_size\_used\_bytes
- nodejs\_version\_info
- process\_cpu\_seconds\_total
- process\_cpu\_system\_seconds\_total
- process\_cpu\_user\_seconds\_total
- process\_resident\_memory\_bytes
- process\_start\_time\_seconds
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - December 2025
* Chore: Fix incorrect semver to 1.0.0. No further changes
# 0.0.5 - August 2023
# 0.0.4 - June 2022
* Updated instructions to instrument Apollo server
# 0.0.3 - June 2022
* Update mixin to latest version:
  - Fixed labeling, and multi-select options for job and instance dashboard template variables
  - Added regex matching to job and instance promql matching
# 0.0.2 - October 2021
* Update all rate queries to use `$__rate_interval` so they respect the default resolution
# 0.0.1 - December 2020
* Initial release
## Cost
By connecting your Apollo Server instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
