title: "Apache Tomcat integration | Grafana Cloud documentation"
description: "Learn about Apache Tomcat Grafana Cloud integration."
# Apache Tomcat integration for Grafana Cloud
Apache Tomcat is an open source web server and servlet container that can run Java-based web applications. This integration for Grafana Cloud allows users to collect metrics and logs for monitoring an Apache Tomcat instance.
Metrics include virtual memory and cpu usage, traffic sent and received, total requests and processing time, threads, sessions and session processing time, and servlet requests and servlet processing time.
This integration includes 4 useful alerts and 3 pre-built dashboards to help monitor and visualize Apache Tomcat metrics and logs.
## Before you begin
In order for the integration to properly work, you must set up the [JMX Exporter for Prometheus](https://github.com/prometheus/jmx_exporter) to export metrics from Tomcat.
#### Set up JMX Exporter
Use this [Apache Tomcat JMX Exporter configuration file](https://storage.googleapis.com/grafanalabs-integration-assets/apache-tomcat/files/tomcat.yml). You can deploy it as either a [Java agent](https://github.com/prometheus/jmx_exporter#java-agent) (recommended) or [standalone exporter](https://prometheus.github.io/jmx_exporter/1.1.0/standalone/).
When using the Java agent, you do not need to configure `jmxUrl` in the exporter config. For JVM options, agent arguments, or standalone configuration details, see the [JMX Exporter documentation](https://github.com/prometheus/jmx_exporter#jmx-exporter).
Once deployed, Grafana Alloy should be able to reach the JMX Exporter HTTP endpoint in order to scrape metrics.
## Install Apache Tomcat integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **Apache Tomcat** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send Apache Tomcat metrics and logs to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Apache Tomcat setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single Apache Tomcat node running locally with default ports.
**Manually** copy and append the following snippets into your Grafana Alloy configuration file.
### Metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_tomcat" {
    targets = [{
        __address__ = "localhost:9010",
    rule {
        target_label = "instance"
prometheus.scrape "metrics_integrations_tomcat" {
    targets    = discovery.relabel.metrics_integrations_tomcat.output
    job_name   = "integrations/tomcat"
### Logs snippets
#### darwin
```alloy
local.file_match "logs_integrations_tomcat_linux" {
    path_targets = [{
        __address__ = "localhost",
        __path__    = "/{var,opt,usr/local}/{log,*tomcat*}/{*tomcat*,logs}/catalina.out",
        instance    = constants.hostname,
        job         = "integrations/tomcat",
loki.source.file "logs_integrations_tomcat_linux" {
    targets    = local.file_match.logs_integrations_tomcat_linux.targets
    forward_to = [loki.write.grafana_cloud_loki.receiver]
#### linux
```alloy
    path_targets = [{
#### windows
```alloy
local.file_match "logs_integrations_tomcat_windows" {
    path_targets = [{
        __path__    = "/Program Files/Apache Software Foundation/Tomcat *.*/logs/catalina.out",
loki.source.file "logs_integrations_tomcat_windows" {
    targets    = local.file_match.logs_integrations_tomcat_windows.targets
### Advanced mode
To instruct Grafana Alloy to scrape your Apache Tomcat nodes, go though the subsequent instructions.
The snippets provide examples to guide you through the configuration process.
First, **manually** copy and append the following snippets into your Grafana Alloy configuration file.
Then follow the instructions below to modify the necessary variables.
### Advanced metrics snippets
```alloy
    targets = [{
    rule {
After enabling the JMX exporter in your Apache Tomcat node, instruct Grafana Alloy to scrape it.
One [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel) must be added for each Apache Tomcat node.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to the JMX exporter metrics endpoint.
- `instance`: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Apache Tomcat instance. Make sure this label value is the same for all telemetry data collected for this instance.
Finally, reference each `discovery.relabel` component within the `targets` property of the [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component.
### Advanced logs snippets
#### darwin
```alloy
    path_targets = [{
To collect logs from unix-like systems, you need a pair of [loki.source.file](/docs/alloy/latest/reference/components/loki.source.file/), and [local.file\_match](/docs/alloy/latest/reference/components/local.file_match/) components of Grafana Alloy.
The provided snippet is pre-configured with the default log write location for unix-like environments.
If you wish to capture other log files, you must add new maps to the `path_targets` list parameter of the `local.file_match` component, and include it in the `targets` list of `loki.source.file` component. Make sure that the new entry has the same instance and job labels, so it is matched to the correct instance to be shown in the Logs dashboard.
#### linux
```alloy
    path_targets = [{
#### windows
```alloy
    path_targets = [{
To collect logs from Windows systems, you need a pair of [`loki.source.file`](/docs/alloy/latest/reference/components/loki.source.file/), and [`local.file_match`](/docs/alloy/latest/reference/components/local.file_match/) components of Grafana Alloy.
The provided snippet is pre-configured with the default log write location for Windows environments.
## Kubernetes instructions
Instructions for Kubernetes
### Before you begin with Kubernetes
**Please note**: These instructions assume the use of the [Kubernetes Monitoring Helm chart](https://github.com/grafana/k8s-monitoring-helm)
To enable JMX collection, make sure your Tomcat instance is configured with the following CATALINA\_OPTS:
```none
-Dcom.sun.management.jmxremote
-Dcom.sun.management.jmxremote.port=9010
-Dcom.sun.management.jmxremote.authenticate=false
-Dcom.sun.management.jmxremote.ssl=false
The JMX Exporter can be run with this [Apache Tomcat JMX Exporter configuration file](https://storage.googleapis.com/grafanalabs-integration-assets/apache-tomcat/files/tomcat.yml).
For more information on how to configure the JVM, please refer to the [JMX Exporter documentation](https://github.com/prometheus/jmx_exporter#jmx-exporter) for further configuration.
Apache Tomcat exposes `9010` for JMX by default, but feel free to change the port to match your environment. The JMX URL for the exporter should be properly configured to match e.g. `jmxUrl: service:jmx:rmi:///jndi/rmi://localhost:9010/jmxrmi`
### Configuration snippets for Kubernetes Helm chart
To scrape your Apache Tomcat instances, **manually** modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets `<>` in the provided snippets with your desired configuration values.
#### Metrics snippets
```alloy
alloy-metrics:
    extraConfig: |-
        discovery.kubernetes "tomcat_service_jmx" {
            role = "service"
            selectors {
                role = "service"
                field = "metadata.name=<tomcat-service-name>"
            namespaces {
                names = [<tomcat-namespace>]
        discovery.relabel "tomcat_service_jmx" {
            targets = discovery.kubernetes.tomcat_service_jmx.targets
            rule {
            source_labels = ["__meta_kubernetes_service_port_name"]
            action        = "keep"
            regex         = "<jmx-port-name>"
            rule {
            replacement  = "integrations/apache-tomcat"
            target_label = "job"
        prometheus.scrape "tomcat_metrics" {
        targets    = discovery.relabel.tomcat_service_jmx.output
        job_name   = "integrations/apache-tomcat"
        forward_to = [prometheus.remote_write.grafana_cloud_metrics.receiver]
#### Logs snippets
```alloy
podLogs:
    extraDiscoveryRules: |-
        rule {
            source_labels = ["__meta_kubernetes_namespace", "__meta_kubernetes_pod_name", "__meta_kubernetes_pod_container_name"]
            separator     = ":"
            regex         = "(<tomcat-namespace>:<tomcat-pod-name>:<tomcat-container-name>)"
            replacement   = "apache-tomcat"
            target_label  = "integration"
        rule {
            source_labels = ["integration"]
            regex         = "apache-tomcat"
            replacement   = "catalina.out"
            target_label  = "log_type"
        rule {
            replacement   = "<tomcat-service-name>.<tomcat-namespace>.svc:<jmx-exporter-port>"
        rule {
## Dashboards
The Apache Tomcat integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Apache Tomcat hosts
- Apache Tomcat logs
- Apache Tomcat overview
**Apache Tomcat overview dashboard 1**
**Apache Tomcat overview dashboard 2**
**Apache Tomcat overview dashboard 3**
## Alerts
The Apache Tomcat integration includes the following useful alerts:
Expand table
| Alert                                | Description        |
| ApacheTomcatAlertsHighCpuUsage       | Critical: The instance has a CPU usage higher than the configured threshold.    |
| ApacheTomcatAlertsHighMemoryUsage    | Critical: The instance has a higher memory usage than the configured threshold. |
| ApacheTomcatAlertsRequestErrors      | Critical: There are a high number of request errors.                            |
| ApacheTomcatAlertsHighProcessingTime | Warning: The processing time has been moderately high.                          |
## Metrics
The most important metrics provided by the Apache Tomcat integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- jvm\_memory\_usage\_used\_bytes
- jvm\_physical\_memory\_bytes
- jvm\_process\_cpu\_load
- tomcat\_bytesreceived\_total
- tomcat\_bytessent\_total
- tomcat\_errorcount\_total
- tomcat\_processingtime\_total
- tomcat\_requestcount\_total
- tomcat\_servlet\_errorcount\_total
- tomcat\_servlet\_processingtime\_total
- tomcat\_servlet\_requestcount\_total
- tomcat\_session\_expiredsessions\_total
- tomcat\_session\_processingtime\_total
- tomcat\_session\_rejectedsessions\_total
- tomcat\_session\_sessioncounter\_total
- tomcat\_threadpool\_connectioncount
- tomcat\_threadpool\_currentthreadcount
- tomcat\_threadpool\_keepalivecount
- tomcat\_threadpool\_pollerthreadcount
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.2.0 - May 2026
* Updated dashboards to follow new stylistic standards
* Renamed alert `ApacheTomcatAlertsHighRequestErrorPercent` to `ApacheTomcatAlertsRequestErrors`
* Renamed alert `ApacheTomcatAlertsModeratelyHighProcessingTime` to `ApacheTomcatAlertsHighProcessingTime`
* Added an `Apache Tomcat logs` dashboard
# 1.1.1 - November 2024
* Fix metric & log check queries
# 1.1.0 - September 2024
* Added Asserts support
# 1.0.1 - March 2024
* Updated to latest Mixin to fix CPU and Memory Alert queries
# 1.0.0 - October 2023
* Added Grafana Agent Operator configuration snippet to support Tomcat in kubernetes cluster
* Added cluster selector to dashboard for kubernetes support
# 0.0.4 - September 2023
# 0.0.3 - August 2023
# 0.0.2 - July 2023
* Update mixin to latest version
  - Adds an `instance` and `job` filter for the logs panel to only show this integration's logs
# 0.0.1 - April 2023
* Initial release
## Cost
By connecting your Apache Tomcat instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
