title: "Apache Airflow integration | Grafana Cloud documentation"
description: "Learn about Apache Airflow Grafana Cloud integration."
# Apache Airflow integration for Grafana Cloud
Apache Airflow is an open-source platform for programmatically authoring, scheduling, and monitoring workflows, enabling the orchestration of complex data pipelines and task dependencies. This integration for Grafana Cloud allows users to collect metrics, scheduler logs, and task logs for monitoring an Apache Airflow system.
Metrics include DAG (Directed Acyclic Graph) failures, DAG durations, task failures, task durations, scheduler details, executor tasks, and pool task slots for an Apache Airflow system.
This integration supports Apache Airflow versions 2.5.0+.
This integration includes 4 useful alerts and 1 pre-built dashboard to help monitor and visualize Apache Airflow metrics and logs.
## Before you begin
In order for the integration to properly work, Airflow must be setup to [send metrics to StatsD](https://airflow.apache.org/docs/apache-airflow/2.5.0/logging-monitoring/metrics.html).
#### Setup Airflow to send metrics to StatsD
First you must install the StatsD requirement:
![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```none
pip install 'apache-airflow[statsd]'
Also, the following lines must be added to your airflow.cfg:
```none
[metrics]
statsd_on = True
statsd_host = localhost
statsd_port = 8125
statsd_prefix = airflow
## Install Apache Airflow integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **Apache Airflow** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send Apache Airflow metrics and logs to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your Apache Airflow setup.
## Configuration snippets for Grafana Alloy
### Simple mode
These snippets are configured to scrape a single Apache Airflow instance running locally with default ports.
First, **manually** copy and append the following snippets into your alloy configuration file.
## Metrics instructions
This integration uses the [prometheus.exporter.statsd](/docs/alloy/latest/reference/components/prometheus.exporter.statsd/) component to generate metrics from a Apache Airflow instance.
Make sure to change `listen_udp` in the snippet according to your environment.
The statsd exporter component requires an external mapping configuration file. You can download the correct mapping file for this integration [here](https://storage.googleapis.com/grafanalabs-integration-assets/apache-airflow/files/stats_mapping.yaml).
> If you’re deploying to Kubernetes using the [official helm chart](https://artifacthub.io/packages/helm/apache-airflow/airflow), the statsd exporter is included with a custom mapping configuration, but the configuration will need to be [updated](https://storage.googleapis.com/grafanalabs-integration-assets/apache-airflow/files/stats_mapping.yaml).
For the full array of configuration options, refer to the [prometheus.exporter.statsd](/docs/alloy/latest/reference/components/prometheus.exporter.statsd/) component reference documentation.
This exporter must be linked with a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to apply the necessary relabelings.
For each Apache Airflow instance to be monitored you must create a pair of these components.
Configure the following properties within each `discovery.relabel` component:
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Apache Airflow instance. Make sure this label value is the same for all telemetry data collected for this instance.
You can then scrape them by including each `discovery.relabel` under `targets` within the [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape/) component.
### Integrations snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
prometheus.exporter.statsd "integrations_statsd_exporter" {
	listen_udp = "localhost:8125"
  mapping_config_path = "statsd_mapping.yaml"
discovery.relabel "integrations_statsd_exporter" {
	targets = prometheus.exporter.statsd.integrations_statsd_exporter.targets
	rule {
		target_label = "job"
		replacement  = "integrations/apache-airflow"
	rule {
		target_label = "instance"
prometheus.scrape "integrations_statsd_exporter" {
	targets    = discovery.relabel.integrations_statsd_exporter.output
	job_name   = "integrations/statsd_exporter"
### Advanced mode
To instruct Grafana Alloy to scrape your Apache Airflow instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced integrations snippets
```alloy
	rule {
	rule {
### Advanced logs snippets
#### darwin
```alloy
local.file_match "logs_integrations_integrations_apache_airflow" {
	path_targets = [{
		__address__ = "localhost",
		__path__    = "<airflow_home>/logs/dag_id=*/**/*.log",
		instance    = constants.hostname,
		job         = "integrations/apache-airflow",
		__path__    = "<airflow_home>/logs/scheduler/latest/*.py.log",
loki.process "logs_integrations_integrations_apache_airflow" {
	forward_to = [loki.write.grafana_cloud_loki.receiver]
	stage.match {
		selector = format("{job=\"integrations/apache-airflow\",instance=\"%s\"}", constants.hostname)
		stage.regex {
			expression = "<airflow_home>/logs/dag_id=(?P<dag_id>\\S+?)/.*/task_id=(?P<task_id>\\S+?)/.*log"
			source     = "filename"
		stage.labels {
			values = {
				dag_id  = null,
				task_id = null,
	stage.match {
		stage.regex {
			expression = "<airflow_home>/logs/scheduler/latest/(?P<dag_file>\\S+?)\\.log"
			source     = "filename"
		stage.labels {
			values = {
				dag_file = null,
	stage.multiline {
		firstline     = "\\[\\d+-\\d+-\\d+T\\d+:\\d+:\\d+\\.\\d+\\+\\d+\\]"
		max_lines     = 0
		max_wait_time = "3s"
loki.source.file "logs_integrations_integrations_apache_airflow" {
	targets    = local.file_match.logs_integrations_integrations_apache_airflow.targets
	forward_to = [loki.process.logs_integrations_integrations_apache_airflow.receiver]
To monitor your Apache Airflow instance logs, you will use a combination of the following components:
> If you’re deploying to Kubernetes using the [official helm chart](https://artifacthub.io/packages/helm/apache-airflow/airflow), the scheduler and task logs will need to be persisted to a volume and an additional Alloy pod will need to be deployed with those volumes mounted.
- [local.file\_match](/docs/alloy/latest/reference/components/local.file_match) defines where to find the log file to be scraped. Change the following properties according to your environment:
  - `__address__`: The Apache Airflow instance address
  - `__path__`: The path to the log file.
- [loki.process](/docs/alloy/latest/reference/components/loki.process) defines how to process logs before sending it to Loki.
- [loki.source.file](/docs/alloy/latest/reference/components/loki.source.file) sends logs to Loki.
#### Kubernetes sidecars for log collection
If you’re running Airflow using the official helm chart, additional steps are required for collecting logs from the environment.
##### ConfigMaps
You’ll want to clone down the repo, as the `extraConfigMaps` configuration in `values.yaml` is not suitable. You’ll have to add additional YAML files to the `/templates/configmaps` directory.
Here are examples from the sample application for the Alloy configurations that will need to be tailored to your environment.
- [Scheduler logs configuration](https://github.com/grafana/integration-sample-apps/blob/main/charts/apache-airflow/templates/configmaps/alloy-airflow-scheduler-logs-configmap.yaml)
- [Task logs configuration](https://github.com/grafana/integration-sample-apps/blob/main/charts/apache-airflow/templates/configmaps/alloy-airflow-task-logs-configmap.yaml)
##### Sidecars
To setup the Alloy sidecars for the task and scheduler logs, you’ll update the `values.yaml` file. There are `extraContainers` sections for the worker and scheduler pods.
Here’s example YAML for the task logs sidecar container. It will be Alloy with volume mounts for the custom alloy configuration and the Airflow logs directory.
YAML ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```yaml
  extraContainers:
    - name: alloy
      image: grafana/alloy:latest
      volumeMounts:
      - name: alloy-task-logs-config
        mountPath: /etc/alloy/config.alloy
        subPath: config.alloy
      - name: logs
        mountPath: /opt/airflow/logs/
      securityContext:
        runAsUser: 0
        runAsGroup: 0
Following the addition of the Alloy configurations and the Alloy sidecars, log collection should be working.
#### linux
```alloy
	path_targets = [{
	stage.match {
		stage.regex {
			source     = "filename"
		stage.labels {
			values = {
				dag_id  = null,
				task_id = null,
	stage.match {
		stage.regex {
			source     = "filename"
		stage.labels {
			values = {
				dag_file = null,
	stage.multiline {
		max_lines     = 0
##### ConfigMaps
##### Sidecars
```yaml
  extraContainers:
    - name: alloy
      volumeMounts:
      - name: logs
      securityContext:
        runAsUser: 0
        runAsGroup: 0
## Kubernetes instructions
Instructions for Kubernetes
### Before you begin with Kubernetes
**Please note**: These instructions assume the use of the [Kubernetes Monitoring Helm chart](https://github.com/grafana/k8s-monitoring-helm)
```none
```none
[metrics]
statsd_on = True
statsd_port = 8125
### Configuration snippets for Kubernetes Helm chart
To scrape your Apache Airflow instances, **manually** modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets `<>` in the provided snippets with your desired configuration values.
#### Metrics snippets
```alloy
alloy-metrics:
    extraConfig: |-
        prometheus.scrape "integrations_airflow_statsd_exporter" {
            targets    = [{"__address__" = "<airflow-statsd-service>.<airflow-namespace>.svc.cluster.local:9102"}]
            forward_to = [prometheus.remote_write.grafana_cloud_metrics.receiver]
            job_name   = "integrations/apache-airflow"
#### Logs snippets
```alloy
<q>These instructions are being written under the assumption that the <a href="https://airflow.apache.org/docs/helm-chart/stable/index.html">official helm chart</a> is in use. If not, there may be additional work.</q>
<p>
To collect logs from Apache Airflow, Alloy sidecars must be added to the deployment configuration for the scheduler and worker pods.
</p>
<p>
Please refer to <a href="https://grafana.com/docs/grafana-cloud/monitor-infrastructure/integrations/integration-reference/integration-apache-airflow/#kubernetes-sidecars-for-log-collection-1">these instructions for further details</a>.
</p>
## Dashboards
The Apache Airflow integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Apache Airflow overview
**Apache Airflow overview (general)**
**Apache Airflow overview (scheduler)**
## Alerts
The Apache Airflow integration includes the following useful alerts:
Expand table
| Alert                                      | Description        |
| ApacheAirflowStarvingPoolTasks             | Critical: There are starved tasks detected in the Apache Airflow pool.                       |
| ApacheAirflowDAGScheduleDelayWarningLevel  | Warning: The delay in DAG schedule time to DAG run time has reached the warning threshold.   |
| ApacheAirflowDAGScheduleDelayCriticalLevel | Critical: The delay in DAG schedule time to DAG run time has reached the critical threshold. |
| ApacheAirflowDAGFailures                   | Critical: There have been DAG failures detected.                                             |
## Metrics
The most important metrics provided by the Apache Airflow integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- airflow\_dag\_processing\_import\_errors
- airflow\_dag\_task\_duration\_count
- airflow\_dag\_task\_duration\_sum
- airflow\_dagrun\_duration\_failed\_count
- airflow\_dagrun\_duration\_failed\_sum
- airflow\_dagrun\_duration\_success\_count
- airflow\_dagrun\_duration\_success\_sum
- airflow\_dagrun\_schedule\_delay\_count
- airflow\_dagrun\_schedule\_delay\_sum
- airflow\_executor\_open\_slots
- airflow\_executor\_queued\_tasks
- airflow\_executor\_running\_tasks
- airflow\_pool\_open\_slots
- airflow\_pool\_queued\_slots
- airflow\_pool\_running\_slots
- airflow\_pool\_starving\_tasks
- airflow\_scheduler\_tasks\_executable
- airflow\_scheduler\_tasks\_starving
- airflow\_sla\_missed
- airflow\_task\_finish\_total
- airflow\_task\_start\_total
- airflow\_ti\_failures
- up
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - June 2024
* Added cluster selector to dashboards for kubernetes support
* Added default cluster label to agent config
# 0.0.4 - September 2023
* Update Grafana Agent configuration snippets to include filtered metrics used in gauge panels
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - June 2023
* Initial release
## Cost
By connecting your Apache Airflow instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
