This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/monitor-applications/ai-observability.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/monitor-applications/ai-observability/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
AI Observability
Note
To monitor and observe LLM agents in production, refer to the Machine Learning AI Observability documentation.
Overview
Grafana AI Observability is a complete solution designed to monitor and optimize your entire AI stack. It provides end-to-end observability across all components of your AI stack.
GenAI observability
- Performance tracking: Monitor LLM response times, throughput, and availability across providers
- Cost management: Real-time spend tracking, cost optimization, and budget management for LLM usage
- Token analytics: Track consumption patterns, efficiency metrics, and usage optimization opportunities
- User interactions: Gain insights into user interactions, prompts, and completions for performance understanding
GenAI evaluations
- Quality assessment: Automated hallucination detection, factual accuracy verification, and content quality scoring
- Safety monitoring: Continuous toxicity detection, bias assessment, and compliance tracking for responsible AI
- Evaluation scoring: Confidence levels, quality gates, and automated quality assurance workflows
- Problem identification: Detailed analysis and categorization of AI model issues and failure patterns
GenAI Agent Observability
- Invocation tracking: Monitor total agent invocations, usage distribution by source, and percentage breakdown across your agentic AI systems
- Cost management: Real-time tracking of total agent costs in USD, per-agent cost breakdown, and cost attribution for budget optimization
- Performance monitoring: Track 95th percentile operation duration, average latency by agent and provider, and operation throughput rates
- Logs and debugging: Integrated agent logs with OpenTelemetry trace and span ID correlation for distributed tracing and root cause analysis
VectorDB observability
- Query performance: Monitor similarity search response times, throughput, and query optimization
- Database operations: Track insert, update, and delete operations across different vector database providers
- Resource utilization: Monitor memory usage, storage efficiency, and infrastructure scaling needs
- Index management: Track index building, optimization, and maintenance for optimal search performance
MCP observability
- Protocol health: Track session management, connection stability, and protocol compliance metrics
- Tool analytics: Monitor tool usage patterns, performance, and availability across your AI ecosystem
- Transport monitoring: Analyze communication performance across HTTP, WebSocket, and other transport layers
- Integration insights: Track tool invocation patterns, payload analysis, and system reliability
GPU observability
- Performance monitoring: Track GPU utilization, compute efficiency, and processing throughput
- Thermal management: Monitor temperatures, cooling systems, and prevent thermal throttling
- Resource optimization: Analyze memory usage, power consumption, and multi-GPU coordination
- Infrastructure health: Monitor hardware status, driver stability, and predictive maintenance metrics
Explore
Was this page helpful?
