Control Graphite metrics usage
This guide will help you analyze and reduce your Graphite metrics usage.
To learn how to analyze your Graphite metrics usage for common metric prefixes and high-cardinality metrics, please see Analyzing Graphite metrics usage.
If you already know which high-cardinality metrics you want to drop, please consult Reducing Graphite metrics usage.
Related Grafana Cloud resources
Intro to Prometheus and Grafana Cloud
Prometheus is taking over the monitoring world! In this webinar, we will start with a quick introduction to the open source project that’s the de facto standard for monitoring modern, cloud native systems.
How to set up and visualize synthetic monitoring at scale with Grafana Cloud
Learn how to use Kubernetes, Grafana Loki, and Grafana Cloud’s synthetic monitoring feature to set up your infrastructure's checks in this GrafanaCONline session.
Using Grafana Cloud to drive manufacturing plant efficiency
This GrafanaCONline session tells how Grafana helps a 75-year-old manufacturing company with product quality and equipment maintenance.
