This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/learn-and-build/as-code/terraform/terraform-plugins.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/learn-and-build/as-code/terraform/terraform-plugins/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Install plugins in Grafana Cloud using Terraform
This guide shows you how to install plugins in Grafana Cloud using Terraform. For more information about Grafana plugins, refer to the Find and use Grafana plugins documentation.
Before you begin
Before you begin, ensure you have the following:
- A Grafana Cloud account; for more information on setting up a Grafana Cloud account, refer to Get started.
- Terraform installed on your machine; for more information on how to install Terraform, refer to the Terraform install documentation.
- Administrator permissions in your Grafana instance; for more information on assigning Grafana RBAC roles, refer to Assign RBAC roles.
Note
Save all of the following Terraform configuration files in the same directory.
Configure the Grafana provider
Use this Terraform configuration to set up the Grafana provider to provide the authentication required to manage plugin resources.
Create a service account and token in Grafana. For more information on creating a service account and token, refer to Service account tokens. You can also refer to Creating and managing a Grafana Cloud stack using Terraform to set up a service account and a token.
Make sure that the token has the following permissions:
stack-plugins:readstack-plugins:writestack-plugins:delete
Next, create a file named main.tf and add the following:
terraform {
required_providers {
grafana = {
source = "grafana/grafana"
version = ">= 4.5.3"
provider "grafana" {
cloud_api_url = "<Stack-URL>"
cloud_access_policy_token = "<Service-account-token>"
}Replace the following field values:
Stack-URLwith the URL of your Grafana stack, for examplehttps://my-stack.grafana.net/Service-account-tokenwith the service account token that you created
Create new plugin resource
Create a file named plugins.tf and add the following:
resource "grafana_cloud_plugin_installation" "grafana-clock-panel" {
stack_slug = "<Your-Stack-Slug>"
slug = "grafana-clock-panel"
version = "latest"
}Summary
In this guide, you learned how to install a plugin in Grafana Cloud using Terraform.
To learn more about plugin installation, refer to the Grafana provider documentation.
Was this page helpful?
