title: "Manage Fleet Management in Grafana Cloud using Terraform | Grafana Cloud documentation"
description: "Learn how to create Grafana Fleet Management collectors and pipelines in Grafana Cloud using Terraform"
# Manage Fleet Management in Grafana Cloud using Terraform
Learn how to create [Grafana Fleet Management](https://grafana.com/docs/grafana-cloud/send-data/fleet-management/) collectors and pipelines in Grafana Cloud using Terraform. This guide shows you how to create an access policy and a token for Fleet Management, preregister a collector with remote attributes, and create a configuration pipeline.
Fleet Management supports [Grafana Alloy](https://grafana.com/docs/grafana-cloud/send-data/alloy/) and the [OpenTelemetry Collector](https://opentelemetry.io/docs/collector/). The two collector types connect to Fleet Management differently and use different configuration syntax, so this guide shows both paths side by side. Follow the Alloy steps, the OpenTelemetry Collector steps, or both if you’re managing a mixed fleet.
## Before you begin
Before you begin, ensure you have the following:
- A Grafana Cloud account, as shown in [Get started](https://grafana.com/docs/grafana-cloud/get-started/)
- Administrator permissions in your Grafana instance
- [Terraform](https://www.terraform.io/downloads) installed on your machine
- One of the following collectors installed on your machine:
  - [Alloy](https://grafana.com/docs/grafana-cloud/send-data/alloy/set-up/install/)
  - A supported OpenTelemetry Collector distribution that includes the [OpAMP extension](https://github.com/open-telemetry/opentelemetry-collector-contrib/tree/main/extension/opampextension) (for example, `otelcol-contrib`) If using the OpenTelemetry Collector, you must also install the [OpAMP Supervisor](https://github.com/open-telemetry/opentelemetry-collector-contrib/tree/main/cmd/opampsupervisor).
> Note
> All of the following Terraform configuration files should be saved in the same directory.
## Configure a provider for Grafana Cloud
This Terraform configuration configures the [Grafana provider](https://registry.terraform.io/providers/grafana/grafana/latest/docs) to provide necessary authentication when interacting with the Cloud API. The [`grafana_cloud_stack` (Data Source)](https://registry.terraform.io/providers/grafana/grafana/latest/docs/data-sources/cloud_stack) is used to retrieve the user ID and URL details of your instance.
1. Create a Grafana Cloud access policy and token. To create a new one, refer to [Grafana Cloud Access Policies](https://grafana.com/docs/grafana-cloud/security-and-account-management/authentication-and-permissions/access-policies/). Add your stack to the realms list. The scopes needed for the examples in this guide are:
   - `accesspolicies:read`
   - `accesspolicies:write`
   - `accesspolicies:delete`
   - `stacks:read`
2. Create a file named `cloud-provider.tf` and add the following code block:
   terraform ![Copy code to clipboard](https://grafana.com/media/images/icons/icon-copy-small-2.svg) Copy
   ```terraform
   terraform {
     required_providers {
       grafana = {
         source  = "grafana/grafana"
         version = ">= 3.19.0"
   provider "grafana" {
     alias = "cloud"
     cloud_access_policy_token = "<CLOUD_ACCESS_POLICY_TOKEN>"
   data "grafana_cloud_stack" "stack" {
     provider = grafana.cloud
     slug = "<STACK_SLUG>"
3. Replace the following field values:
   - `<CLOUD_ACCESS_POLICY_TOKEN>` with the access policy token you created in the first step
   - `<STACK_SLUG>` with your stack slug, which is the subdomain where your Grafana Cloud instance is available: `https://<STACK_SLUG>.grafana.net`
## Create an access policy and token for Fleet Management
This Terraform configuration creates the following:
- An access policy named `fleet-management-policy` with `fleet-management:read` and `fleet-management:write` scopes, using [`grafana_cloud_access_policy` (Resource)](https://registry.terraform.io/providers/grafana/grafana/latest/docs/resources/cloud_access_policy)
- A token named `fleet-management-token`, using [`grafana_cloud_access_policy_token` (Resource)](https://registry.terraform.io/providers/grafana/grafana/latest/docs/resources/cloud_access_policy_token)
<!--THE END-->
1. Create a file named `fm-access-policy.tf` and add the following code block:
   ```terraform
   resource "grafana_cloud_access_policy" "fm_policy" {
     name   = "fleet-management-policy"
     region = data.grafana_cloud_stack.stack.region_slug
     scopes = [
       "fleet-management:read",
       "fleet-management:write"
     realm {
       type       = "stack"
       identifier = data.grafana_cloud_stack.stack.id
   resource "grafana_cloud_access_policy_token" "fm_token" {
     name             = "fleet-management-token"
     region           = grafana_cloud_access_policy.fm_policy.region
     access_policy_id = grafana_cloud_access_policy.fm_policy.policy_id
## Configure a provider for Fleet Management
This Terraform configuration configures the [Grafana provider](https://registry.terraform.io/providers/grafana/grafana/latest/docs) to provide necessary authentication when interacting with the Fleet Management API.
1. Create a file named `fm-provider.tf` and add the following code block:
   ```terraform
   locals {
     fm_id    = data.grafana_cloud_stack.stack.fleet_management_user_id
     fm_token = grafana_cloud_access_policy_token.fm_token.token
     fm_url   = data.grafana_cloud_stack.stack.fleet_management_url
     alias = "fm"
     fleet_management_auth = "${local.fm_id}:${local.fm_token}"
     fleet_management_url  = local.fm_url
## Create an access policy and token for your collector
Alloy and the OpenTelemetry Collector need properly scoped access to read remote configuration from Fleet Management and write telemetry to Grafana Cloud.
The Terraform provider creates the `alloy_token` for you when you run `terraform apply` later in this guide.
OpenTelemetry Collectors require an access token *before* you can successfully apply the Terraform configurations. You create the `otel_token` manually in this step, **but you won’t need it until later in the guide**.
### Alloy
- An access policy named `alloy-policy` with `set:alloy-data-write` scope, using [`grafana_cloud_access_policy` (Resource)](https://registry.terraform.io/providers/grafana/grafana/latest/docs/resources/cloud_access_policy)
- A token named `alloy-token`, using [`grafana_cloud_access_policy_token` (Resource)](https://registry.terraform.io/providers/grafana/grafana/latest/docs/resources/cloud_access_policy_token)
<!--THE END-->
1. Create a file named `alloy-access-policy.tf` and add the following code block:
   ```terraform
   resource "grafana_cloud_access_policy" "alloy_policy" {
     name   = "alloy-policy"
     scopes = [
       "set:alloy-data-write"
     realm {
       type       = "stack"
   resource "grafana_cloud_access_policy_token" "alloy_token" {
     name             = "alloy-token"
     region           = grafana_cloud_access_policy.alloy_policy.region
     access_policy_id = grafana_cloud_access_policy.alloy_policy.policy_id
   output "alloy_token" {
     value     = grafana_cloud_access_policy_token.alloy_token.token
     sensitive = true
### OpenTelemetry Collector
- An access policy named `otel-policy` with `set:otel-data-write` scope, using [`grafana_cloud_access_policy` (Resource)](https://registry.terraform.io/providers/grafana/grafana/latest/docs/resources/cloud_access_policy)
- A token named `otel-token`, using [`grafana_cloud_access_policy_token` (Resource)](https://registry.terraform.io/providers/grafana/grafana/latest/docs/resources/cloud_access_policy_token)
<!--THE END-->
1. Create a file named `otel-access-policy.tf` and add the following code block:
   ```terraform
   resource "grafana_cloud_access_policy" "otel_policy" {
     name   = "otel-policy"
     scopes = [
       "set:otel-data-write"
     realm {
       type       = "stack"
   resource "grafana_cloud_access_policy_token" "otel_token" {
     name             = "otel-token"
     region           = grafana_cloud_access_policy.otel_policy.region
     access_policy_id = grafana_cloud_access_policy.otel_policy.policy_id
## Create a configuration file for your collector
In this step, you create a local configuration file for Alloy or the OpAMP Supervisor.
### Alloy
This Terraform configuration creates an Alloy configuration file with the [`remotecfg` block](https://grafana.com/docs/grafana-cloud/send-data/alloy/reference/config-blocks/remotecfg/) for Fleet Management, using [`local_file` (Resource)](https://registry.terraform.io/providers/hashicorp/local/latest/docs/resources/file).
1. Create a file named `config.alloy.tftpl` and add the following content:
   Alloy ![Copy code to clipboard](https://grafana.com/media/images/icons/icon-copy-small-2.svg) Copy
   ```alloy
   remotecfg {
       id             = "${collector_id}"
       url            = "${fm_url}"
       poll_frequency = "60s"
       basic_auth {
           username = "${fm_id}"
           password = sys.env("GCLOUD_RW_API_KEY")
2. Create a file named `alloy-config.tf` and add the following code block:
   ```terraform
   resource "local_file" "alloy_config" {
     filename = "<ALLOY_CONFIG_PATH>"
     content = templatefile(
       "config.alloy.tftpl",
         collector_id = "prod_alloy_collector",
         fm_id        = local.fm_id,
         fm_url       = local.fm_url,
     directory_permission = "0644"
     file_permission      = "0644"
   - `<ALLOY_CONFIG_PATH>` with the path the Alloy configuration file should be written to, for example `config.alloy`
This Terraform configuration creates a Supervisor configuration file that connects the OpenTelemetry Collector to Fleet Management over [OpAMP](https://github.com/open-telemetry/opamp-spec), using [`local_file` (Resource)](https://registry.terraform.io/providers/hashicorp/local/latest/docs/resources/file).
1. Create a file named `supervisor.yaml.tftpl` and add the following content:
   YAML ![Copy code to clipboard](https://grafana.com/media/images/icons/icon-copy-small-2.svg) Copy
   ```yaml
   server:
     endpoint: '${fm_url}/v1/opamp'
     headers:
       Authorization: 'Basic ${fm_auth_base64}'
   capabilities:
     reports_effective_config: true
     accepts_remote_config: true
   agent:
     executable: '<OTELCOL_EXECUTABLE_PATH>'
     instance_id: '${collector_id}'
   storage:
     directory: '<STORAGE_DIRECTORY>'
2. Create a file named `otel-supervisor-config.tf` and add the following code block:
   ```terraform
   resource "local_file" "otel_supervisor_config" {
     filename = "${path.module}/supervisor.yaml"
       "supervisor.yaml.tftpl",
         collector_id   = "<COLLECTOR_ID>"
         fm_auth_base64 = base64encode("${local.fm_id}:${grafana_cloud_access_policy_token.otel_token.token}"),
   - `<OTELCOL_EXECUTABLE_PATH>` with the path to your OpenTelemetry Collector executable
   - `<STORAGE_DIRECTORY>` with the path to a writable directory to use for [persistent data storage](https://github.com/open-telemetry/opentelemetry-collector-contrib/blob/main/cmd/opampsupervisor/README.md#persistent-data-storage)
   - `<COLLECTOR_ID>` with the universally unique identifier (UUID) of the Collector.
## Create a Fleet Management collector
This step registers a collector with a remote attribute, using [`grafana_fleet_management_collector` (Resource)](https://registry.terraform.io/providers/grafana/grafana/latest/docs/resources/fleet_management_collector). The `collector_type` argument tells Fleet Management which configuration syntax and validation to expect for the collector: `ALLOY` (the default) or `OTEL`.
The following configurations only preregister the collector. You must complete the [Run the collector](https://grafana.com/docs/grafana-cloud/learn-and-build/as-code/terraform/terraform-fleet-management/#run-the-collector) step for the collector to connect to Fleet Management and be assigned remote attributes.
### Alloy
1. Create a file named `fm-collector-alloy.tf` and add the following code block:
   ```terraform
   resource "grafana_fleet_management_collector" "fm_collector_alloy" {
     provider = grafana.fm
     collector_type = "ALLOY"
     remote_attributes = {
       "env" = "PROD"
     enabled = true
1. Create a file named `fm-collector-otel.tf` and add the following code block:
   ```terraform
   resource "grafana_fleet_management_collector" "fm_collector_otel" {
     collector_type = "OTEL"
       "env" = "PROD"
     enabled = true
2. Replace `<COLLECTOR_ID>` with the same unique identifier used in the Supervisor configuration.
## Create a Fleet Management pipeline
The following Terraform configurations create pipelines with [matchers](https://grafana.com/docs/grafana-cloud/send-data/fleet-management/introduction/glossary/#attribute-matching) for the collectors declared in the previous step, using [`grafana_fleet_management_pipeline` (Resource)](https://registry.terraform.io/providers/grafana/grafana/latest/docs/resources/fleet_management_pipeline). The `config_type` argument tells Fleet Management how to parse and validate the `contents` argument: `ALLOY` (the default) expects Alloy configuration syntax, and `OTEL` expects OpenTelemetry Collector YAML.
Fleet Management delivers a pipeline only to collectors of the matching `collector_type`, so an `ALLOY` pipeline and an `OTEL` pipeline can safely share the same matchers.
### Alloy profiling pipeline
This pipeline profiles Alloy itself and writes the profiles to [Grafana Cloud Profiles](https://grafana.com/docs/grafana-cloud/monitor-applications/profiles/).
1. Create a file named `profiling.alloy.tftpl` and add the following content:
   ```alloy
   // This pipeline scrapes pprof Go profiles from Alloy and sends them to Pyroscope.
   // It requires the following environment variables to be set where Alloy is running:
   //   Required:
   //     * GCLOUD_RW_API_KEY: The Grafana Cloud API key with write access to Pyroscope.
   //   Optional:
   //     * ALLOY_ADDRESS: The address Alloy listens on. Defaults to 127.0.0.1:12345.
   pyroscope.scrape "alloy" {
       targets = [
               "__address__" = coalesce(
                   sys.env("ALLOY_ADDRESS"),
                   "127.0.0.1:12345",
               "service_name" = "alloy",
       forward_to = [pyroscope.write.grafana_cloud.receiver]
       profiling_config {
           profile.process_cpu {
               enabled = true
           profile.memory {
               enabled = true
           profile.mutex {
               enabled = true
           profile.block {
               enabled = true
           profile.goroutine {
               enabled = true
   pyroscope.write "grafana_cloud" {
       endpoint {
           url = "${profiles_url}"
           basic_auth {
               username = "${profiles_id}"
2. Create a file named `fm-pipeline-alloy-profiles.tf` and add the following code block:
   ```terraform
   locals {
     profiles_id  = data.grafana_cloud_stack.stack.profiles_user_id
     profiles_url = data.grafana_cloud_stack.stack.profiles_url
   resource "grafana_fleet_management_pipeline" "profiles" {
     name        = "alloy_profiling"
     config_type = "ALLOY"
     contents = templatefile(
       "profiling.alloy.tftpl",
         profiles_id  = local.profiles_id,
         profiles_url = local.profiles_url,
     matchers = [
       "env=\"PROD\""
     enabled = true
### OpenTelemetry Collector host metrics pipeline
This pipeline collects host metrics with the [`hostmetrics` receiver](https://github.com/open-telemetry/opentelemetry-collector-contrib/tree/main/receiver/hostmetricsreceiver) and writes them to Grafana Cloud over [OTLP](https://grafana.com/docs/grafana-cloud/send-data/otlp/send-data-otlp/).
1. Create a file named `hostmetrics.otel.yaml.tftpl` and add the following content:
   ```yaml
   # This pipeline collects host metrics and sends them to Grafana Cloud over OTLP.
   receivers:
     hostmetrics:
       scrapers:
         load:
         memory:
   processors:
     resourcedetection:
       detectors: ['env', 'system']
       override: false
     transform/add_host_metric_attributes:
       error_mode: ignore
       metric_statements:
         - context: datapoint
           statements:
             - set(attributes["host.name"], resource.attributes["host.name"])
             - set(attributes["os.type"], resource.attributes["os.type"])
   exporters:
     otlp_http/grafana_cloud:
       endpoint: '<OTLP_ENDPOINT>'
       headers:
         Authorization: 'Basic $${env:GCLOUD_BASIC_AUTH_BASE64}'
       sending_queue:
         enabled: true
         batch: {}
   service:
     pipelines:
       metrics/hostmetrics:
         receivers: [hostmetrics]
         processors: [resourcedetection, transform/add_host_metric_attributes]
         exporters: [otlp_http/grafana_cloud]
2. Replace `<OTLP_ENDPOINT>` with the OTLP endpoint for your stack, which you can find in your Grafana Cloud portal.
3. Create a file named `fm-pipeline-otel-hostmetrics.tf` and add the following code block:
   ```terraform
   resource "grafana_fleet_management_pipeline" "host_metrics" {
     name        = "otel_host_metrics"
     config_type = "OTEL"
     contents = templatefile("hostmetrics.otel.yaml.tftpl", {})
     matchers = [
       "env=\"PROD\""
     enabled = true
## Apply the Terraform configuration
In a terminal, run the following commands from the directory where all of the configuration files are located.
1. Initialize a working directory containing Terraform configuration files:
   shell ![Copy code to clipboard](https://grafana.com/media/images/icons/icon-copy-small-2.svg) Copy
   ```shell
   terraform init
2. Preview the Terraform changes:
   ```shell
   terraform plan
3. Apply the configuration:
   ```shell
   terraform apply
## Run the collector
The final step is to start your collector. Make sure to set an environment variable containing the access token. The pipelines used in this guide won’t work without it.
### Alloy
1. Run the following command to view the Alloy token:
   ```shell
   terraform output -raw alloy_token
2. Set the environment variable `GCLOUD_RW_API_KEY` to the value from the first step.
3. Run Alloy. To learn how to start or restart Alloy, refer to [Run Grafana Alloy](https://grafana.com/docs/grafana-cloud/send-data/alloy/set-up/run/).
1. Run the following command to export the Base64-encoded credentials the Collector uses to send telemetry to Grafana Cloud. Replace `<INSTANCE_ID>` with your actual instance ID, which you can find on the **API** tab in the Fleet Management application.
   ```shell
   export GCLOUD_BASIC_AUTH_BASE64=$(printf '%s' "<INSTANCE_ID>:$(terraform output -raw otel_token)" | base64 | tr -d '\n')
2. Start the Supervisor:
   ```shell
   ./opampsupervisor --config=supervisor.yaml
## Validation
After you apply the changes in the Terraform configurations and run your collector, you should be able to verify the following:
- A collector is added to the Fleet Management **Inventory tab**, showing the `collector_type` you configured (`ALLOY` or `OTEL`):
  [](https://grafana.com/media/docs/fleet-management/screenshot-fleet-management-terraform-validate-collector-otel.png)
- A pipeline is added to the Fleet Management **Remote configuration tab**:
  [](https://grafana.com/media/docs/fleet-management/screenshot-fleet-management-terraform-validate-pipeline-otel.png)
- Telemetry is being exported to Grafana Cloud. For example, host metrics are visible in Grafana Cloud Metrics:
  [](https://grafana.com/media/docs/fleet-management/screenshot-fleet-management-terraform-validate-host-metrics.png)
## Summary
In this guide, you created an access policy and a token for Fleet Management, registered an Alloy instance or OpenTelemetry Collector with remote attributes, and created a configuration pipeline based on collector type, all using Terraform.
To learn more about managing Grafana Cloud using Terraform, refer to the [Grafana provider documentation](https://registry.terraform.io/providers/grafana/grafana/latest/docs).
