Enterprise Open source Grafana Cloud
Usage and performance limitations
Note
Git Sync functionalities are constantly evolving. Contact Grafana for support or to report any issues you encounter and help us improve this feature.
Performance considerations
When Git Sync is enabled, the database load might increase, especially if your Grafana instance has many folders and nested folders. Evaluate the performance impact, if any, in a non-production environment.
Usage tiers and limits
The following Git Sync per-tier limits apply:
TierCloud - FreeCloud - OtherOn-prem OSSOn-prem Enterprise
Amount of repositories11010 (default)10 (default)
Amount of synced resources per repository201,000No limitNo limit
Note
On Grafana Cloud, tier limits can’t be changed from configuration. Contact Support if you need a higher connection limit, or shard by capacity instead of using a single connection per team or microservice.
On self-managed Grafana (OSS or Enterprise), the repository count of 10 in the table is the default, not a hard ceiling. Raise or remove it with [provisioning] max_repositories in the Grafana configuration file. On-prem resources per repository stay unlimited by default (max_resources_per_repository = 0), and you can set a cap if you want one.
Refer to Modify your usage limits for more details.
On Grafana Cloud, the repository-connection limit is a per-stack limit. On self-managed Grafana, the effective limit is whatever you set for max_repositories (default 10).
Do not sync more than 1,000 resources per repository connection as of today. This isn’t an arbitrary cap: beyond roughly 1,000 resources per connection, the sync workflow puts noticeable load on Grafana itself, which may result in slower syncs and increased database load.
Both of these limits are early figures. As Git Sync matures, these limits will raise by orders of magnitude. The goal is for Git Sync to support around 100 repository connections per stack, and up to roughly 1,000 in the longer term, with similar increases to the number of resources you can sync per connection.
If these limits are affecting your use of Git Sync, get in touch and explain your situation. You may also share any ideas or suggestions.
For details on usage and storage limits, refer to Dashboard and folder limits.
Before changing your usage limits, study your specific use case. Design the repository structure carefully, and determine how many repositories and how many resources you can support. For example, setting over 1,000 resources per repository may impact your system’s performance.
In many cases, splitting a single repository across multiple connections, as described in Scale beyond 1,000 resources per repository, is a better option than raising the limits.
On Grafana Cloud, limits are enforced per tier and can’t be edited from configuration. The 10-connection limit can be increased slightly on request, but splitting a single repository across multiple connections is the recommended way to sync more resources without changing tier limits.
Limit increases aren’t granted automatically. When you request one, Support will ask you to describe your use case to understand why the current limits aren’t enough, and assess whether the increase is necessary and safe for your stack’s performance.
Grafana OSS/Enterprise
In Grafana On-prem (OSS or Enterprise), the table value of 10 repositories is only the default, not a hard ceiling. Resources per repository remain unlimited by default. The 1,000-resources-per-connection figure is a performance recommendation, not an on-prem default cap.
If you’re an on-prem user you can change the limits directly through configuration settings, as described below.
To customize the limits use one of these configuration settings:
  • Use max_repositories to set how many repositories you can sync. Default is 10. Set to 0 for unlimited repositories. Refer to max_repositories in the Configure Grafana section to learn more.
  • Use max_resources_per_repository to set the amount of resources per repository to sync. Default is 0 (unlimited). Refer to max_resources_per_repository in the Configure Grafana section to learn more.
If a single repository holds more than 1,000 resources, you don’t have to raise the per-repository limit. Instead, connect the same repository multiple times, with each connection pointing to a different folder (path) in the repository. Each connection syncs its own subset of resources and counts toward the 1,000-resource recommendation independently.
Because a stack allows up to 10 repository connections, this lets you sync up to roughly 10,000 resources from a single repository while keeping each connection within the recommended range.
When you split a single repository across several connections, use folderless sync for each connection. With folder sync (the default), every connection creates its own wrapper folder named after the repository, so splitting the repository would change your folder hierarchy and nest resources one level deeper. Folderless sync places each connection’s resources at the top level, so the split has no effect on how your dashboards and folders are organized in Grafana.
If you need more than that, the 10-connection limit can be increased slightly for Cloud stacks on request. Contact Support to discuss your use case.
On Grafana Cloud, syncing this many resources may also exceed your stack’s maximum number of dashboards. If it does, you’ll need to increase that limit as well. Refer to Dashboard and folder limits to review and adjust your dashboard limits.
Shard by capacity, not by team
When you have many teams or tenants, it’s tempting to create one connection per team so each team maps to its own connection. Avoid this: it consumes connections quickly, doesn’t scale as teams grow, and on Grafana Cloud a single stack can’t be granted the hundreds of connections this would require.
Instead, shard by capacity. Create one repository and group teams into a small number of shard folders, each holding up to about 1,000 resources, and connect each shard folder separately. For example, a customer with 190 teams and 900 resources fits comfortably in a single shard today:
your-org/grafana-manifests/
├── shard-1/        ← ~900 resources today, connected now
│   ├── team-a/
│   ├── team-b/
├── shard-2/        ← empty for now, add a connection when shard-1 approaches 1,000
├── shard-3/        ← add later as you keep growing
└── shard-4/        ← ...up to 10 shards / connections per stack
As the number of resources grows, add shard-2, shard-3, and later shards, and connect each one. You can move teams between shards at any time to balance the load, so you only pay for the connections you actually need and can grow up to the 10-connection limit without restructuring your repository.
If sharding isn’t practical for your setup, try raising the per-connection resource limit modestly, for example from 1,000 to a limit in the 1,200 - 1,500 range. This is a small adjustment for a bit of extra headroom, not an order-of-magnitude increase. Still, do not go beyond 1,500 resources per connection because of the performance impact on Grafana. For substantially larger scales, sharding remains the recommended approach.
Git Sync across multiple organizations
Git Sync works across multiple organizations for self-managed Grafana instances. You can set up Git Sync independently in each of your organizations, and what you sync in one organization does not affect another. Teams that share a single Grafana instance across separate organizations can each manage their own provisioning from Git.
This feature is available starting in Grafana 13.0.4, but not supported until Grafana 13.1.1.
Compatible Git providers
Git Sync is available for any Git provider through a Pure Git repository type, and has specific enhanced integrations for GitHub, GitLab and Bitbucket.
ProviderAvailable inAuthentication
Pure GitCloud, OSS, EnterprisePersonal Access Token
GitHubCloud, OSS, EnterprisePersonal Access Token or GitHub App
GitHub Enterprise (Server and Cloud)Cloud, EnterprisePersonal Access Token or GitHub App
GitLabCloud, EnterprisePersonal Access Token
BitbucketCloud, EnterpriseAPI token with scopes
Note that Pure Git, GitLab and Bitbucket are supported in Grafana v12.4.x or later only. Refer to Enable Git providers to set them up.
To learn more about Git, refer to Getting Started - About Version Control of the Pro Git book in the official Git documentation.
The Pure Git repository type
The Pure Git repository type uses the Smart HTTP protocol v2 (Git over HTTPS), with no provider-specific logic. Pure Git delivers the core Git Sync workflow: your repository is the source of truth, you may edit dashboards in the UI, and Grafana stays in sync.
Note
Pure Git only supports Smart HTTP protocol v2. Earlier protocol versions (v1, v0) and SSH transport are not supported.
Make sure your Git server supports protocol v2 over HTTPS. Some providers, like Azure DevOps, only use v1 and are therefore not compatible with Git Sync.
However, Pure Git doesn’t include any features that require provider APIs, such as webhook-driven instant sync, automated PR comments, or deep links to source files.
Enhanced integrations: GitHub, GitHub Enterprise, GitLab, Bitbucket
If your Git provider is GitHub, GitHub Enterprise (Server and Cloud), GitLab, or Bitbucket, use the enhanced integration. Enhanced integrations understand the platform you’re using, allowing workflows that feel native: automated pull request comments with dashboard previews, instant webhook-based sync, or direct navigation from Grafana to source files in your provider’s UI.
The GitHub enhanced integration is the most feature-complete experience today. It’s available in Grafana OSS, Enterprise, and Cloud, and enables richer pull request workflows, deeper linking between Grafana and GitHub, and tighter integration into review processes.
The GitLab and Bitbucket integrations are only available in Grafana Enterprise and Grafana Cloud. While they’re less developed for the moment, expect continued improvements around pull request workflows, linking, and sync behavior.
Resource support and compatibility
Git Sync only supports dashboards and folders. Alerts, data sources, panels and other resources are not supported yet.
If you’re a Grafana Cloud user, you can check the Grafana roadmap portal to learn about future improvements.
Resource compatibility
If you’re using Git Sync in Grafana OSS or Grafana Enterprise, some supported resources might be in an incompatible data format. If this happens, syncing will be blocked. Compatibility issues will be fixed with an upcoming migration tool.
A resource can be:
Is the resource?CompatibleIncompatible
SupportedThe resource can be managed with Git Sync.The resource is supported but has compatibility issues. It cannot be managed with Git Sync.
UnsupportedThe resource is not supported and cannot be managed with Git Sync.Not applicable.
Nested folders
Git Sync supports up to four nested folders within a repository.
Known limitations
Migration to Git Sync
Full-instance sync is experimental.
When migrating to resources to Git Sync, you can still create, edit or delete resources, but changes may not be exported. The duration of this process depends on the number of resources involved.
Use existing resources
To add existing resources as provisioned Git Sync resources, you can use the Import dashboards tool, save them from the UI, save them as JSON files and commit them to the synced repository, or use gcx. Refer to Export non-provisioned resources from Grafana for more details. When migrating existing dashboards, the folder structure will be replicated in the provisioned repository.
Caution
Git Sync cannot take ownership of a resource while an unmanaged resource with the same UID exists in Grafana, so you may need to manually remove the original resources to ensure the transition to provisioned resources. Since deleting resources implies certain operational caveats, refer to How to delete existing resources in Grafana for more information.
Restore resources
Restoring resources from the UI is currently not possible. As an alternative, you can restore dashboards directly in your GitHub repository by raising a PR, and they will be updated in Grafana.
