This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/learn-and-build/as-code/foundation-sdk/foundation-sdk-key-concepts.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/learn-and-build/as-code/foundation-sdk/foundation-sdk-key-concepts/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Foundation SDK key concepts
The Grafana Foundation SDK is built around a few core concepts that make your dashboards structured, reusable, and strongly typed.
Builders
The SDK follows a builder pattern, which lets you compose dashboards step-by-step using chained method calls.
Almost every piece of the dashboard, including dashboards, panels, rows, queries, and variables, has its own Builder class.
Here are a few you’ve already seen:
DashboardBuilder- Starts the dashboard definition and sets global configuration settings like title, UID, refresh interval, time range, etc.PanelBuilder- Creates individual visualizations like time series panels, stat panels, or log panels.DataqueryBuilder- Defines how a panel fetches data, for example, from Prometheus or thetestdataplugin.
Builders can be chained, so you can fluently compose dashboards in a readable, structured way:
stat.NewPanelBuilder().
Title("Version").
Datasource(testdataRef).
ReduceOptions(common.NewReduceDataOptionsBuilder().
Calcs([]string{"lastNotNull"}).
Fields("/.*/")).
WithTarget(
testdata.NewDataqueryBuilder().
ScenarioId("csv_content").
CsvContent("version\nv1.2.3"),
)new stat.PanelBuilder()
.title('Version')
.reduceOptions(new common.ReduceDataOptionsBuilder().calcs(['lastNotNull']).fields('/.*/'))
.datasource(testdataRef)
.withTarget(new testdata.DataqueryBuilder().scenarioId('csv_content').csvContent('version\nv1.2.3'));Types
The Grafana Foundation SDK uses strong types under the hood to help catch mistakes before you deploy a broken dashboard.
For example:
- When setting a unit, you’ll get autocomplete suggestions for valid Grafana units like
"percent"or"bps". - When defining a time range, you’ll be guided to provide the correct structure, like
fromandtovalues. - When referencing data sources, you’ll use a structured
DataSourceRefobject with definedtypeanduidfields.
This helps you:
- Avoid typos or unsupported configuration values
- Get full autocomplete and inline documentation in your IDE
- Write dashboards that are less error-prone and easier to maintain
Strong typing also makes it easier to build reusable patterns and components with confidence, especially in large codebases or teams.
Options
Most builder methods accept simple values like strings or numbers, but others expect more structured option objects. These are used for things like:
ReduceDataOptions- How to reduce time series data into single values (e.g. last, avg).VizLegendOptions- Configure how the legend of a panel is displayed.CanvasElementOptions- Define how the various components of a Canvas panel should be displayed.
Example using options:
Fields("/.*/"))
)new stat.PanelBuilder().reduceOptions(new common.ReduceDataOptionsBuilder().calcs(['lastNotNull']).fields('/.*/'));By using option builders, you don’t need to manually construct deeply nested configuration objects. Instead, the SDK gives you a typed and guided API that mirrors a dashboards internal structure, making it easier to configure complex options without guesswork or referring back to the JSON schema.
Was this page helpful?
