Menu
Grafana Cloud k6 Projects and users Manage project members
A k6 project member is a Grafana user with access to a particular k6 project. Each member is associated with a role that includes permissions in the project.
Roles
Grafana Cloud k6 uses the following roles to control user access:
  • Admin. Can access to all the resources.
  • Editor. Can create and run tests.
  • Viewer. Can only view tests.
Grant member roles
Before you begin:
  • Ensure that you are an admin of the k6 project.
  • The new project member must be a Grafana organization member and have logged into the Grafana Stack of the k6 project.
Then, to grant a role to a team member in a k6 project, follow these steps:
  1. Click Projects on the k6 sidebar.
  2. Click the Project Settings (gear) icon of the particular project.
  3. Click the Add users button.
  4. In the Email address field, locate and select a user.
  5. In the Role field, select a role.
  6. Click the Add users button.
The following example shows a list as it appears to an admin.
Grafana Cloud k6 - Project Settings
In this view, you can remove a user from the project or change their role.
