Provided instrumentations
The Grafana Faro Web SDK powers the fully managed Frontend Application Observability service in Grafana Cloud, which is in private beta and not yet publicly available.
Instrumentations are data collectors responsible for integrating with the platform, such as a browser API, to collect and parse data and use the Grafana Faro Web SDK core API to report it.
For example, an instrumentation replaces the browser’s console with a custom implementation that collects all the logs and reports them to the Grafana Faro Web SDK core API using the faro.api.pushLog()
function.
By default, the core package of the Grafana Faro Web SDK does not include instrumentations. Instead, they are provided in specific packages for the platform you are using (except for browser tracing instrumentation - see below).
Console
Logs are critical for troubleshooting errors because they provide context and detail into what is happening in your application.
The console instrumentation replaces the browser’s console with a custom implementation that collects all logs, so whenever console.error
(for example) is called, the message is sent as a log to the collector.
Console instrumentation helps you to:
- Determine the context and the root cause of errors
- Capture messages emitted by the application or the libraries it uses
- Monitor your application and determine that it is working as expected
Because the console instrumentation can offer helpful context when you troubleshoot errors, we recommend that you keep this instrumentation enabled. However, enabling log collection for all log levels captures a lot of data that is sent to Grafana Cloud which can increase cost and result in verbose data.
By default, the following log levels are disabled and we recommend that you only enable them if required:
console.debug
console.trace
console.log
How to use the console instrumentation
The following console instrumentation is enabled by default. No additional configuration is required.
initializeFaro({
url: 'https://my-domain.my-tld/collect/{app-key}',
app: {
Note: If you overwrite the
instrumentations
array when you initialize the Grafana Faro Web SDK, you must manually include the console instrumentation.
To manually include the console instrumentation, use the following getWebInstrumentations
helper function.
initializeFaro({
app: {
instrumentations: [
...getWebInstrumentations({
// Optional, if you want to disable the console instrumentation
captureConsole: false,
// Optional, if you want to collect all levels
captureConsoleDisabledLevels: [],
// Optional, if you want to disable only some levels
captureConsoleDisabledLevels: [LogLevel.DEBUG, LogLevel.TRACE],
Alternatively, if you want to fine-tune which instrumentations are enabled, you can use the ConsoleInstrumentation
class.
initializeFaro({
app: {
instrumentations: [
new ConsoleInstrumentation({
disabledLevels: [],
disabledLevels: [LogLevel.DEBUG, LogLevel.TRACE],
Error
Applications can sometimes produce errors, but because they run in a browser, developers are unaware that they are occurring. In addition, users do not always report errors, which adds to the complexity of troubleshooting them.
The error instrumentation subscribes to the browser’s window.onerror
and onunhandledrejection
events to collect them, extract the stacktrace if available, and report them to the Grafana Faro Web SDK core API using the faro.api.pushError()
function.
Tracking errors helps you to:
- Analyze anomalies that occur in your application (crashes, incorrect behaviour etc.)
- Monitor that your application is working as expected
- Detect issues with external systems that your application is using
The error instrumentation should always be enabled as it is the only way to automatically capture errors. You can, however, disable this instrumentation if you are tracking errors by other means.
Note: When an error is caught in a
try/catch
block, the error needs to be re-thrown or reported manually.
const buggyFn = () => {
throw new Error('Buggy function');
try {
buggyFn();
} catch (err) {
// Re-throw the error so it can be caught by the instrumentation
throw err;
// Alternatively, report it manually
faro.api.pushError(err);
How to use the error instrumentation
The following error instrumentation is enabled by default. No additional configuration is required.
initializeFaro({
app: {
instrumentations
array when you initialize the Grafana Faro Web SDK, you must manually include the error instrumentation.
To manually include the error instrumentation, use the following getWebInstrumentations
helper function.
initializeFaro({
app: {
instrumentations: [...getWebInstrumentations()],
Alternatively, if you want to fine-tune which instrumentations are enabled, you can use the following ErrorInstrumentation
class.
initializeFaro({
app: {
instrumentations: [new ErrorsInstrumentation()],
Web Vitals
Web Vitals measure the real-world performance of your site so that developers, site owners, and others can improve it. For more information about Web Vitals, refer to web.dev.
The Web Vitals instrumentation uses the web-vitals package to collect and report data.
Tracking Web Vitals helps you to:
- Analyze the loading times of your pages
- Detect large repaints that take a lot of time
- Detect delays until first inputs from your users
How to use the Web Vitals instrumentation
The following Web Vitals instrumentation is enabled by default. No additional configuration is required.
initializeFaro({
app: {
**Note: ** If you overwrite the
instrumentations
array when you initialize the Grafana Faro Web SDK, you must manually include the Web Vitals instrumentation.
To manually include the Web Vitals instrumentation, use the following getWebInstrumentations
helper function.
initializeFaro({
app: {
Alternatively, if you want to fine-tune which instrumentations are enabled, you can use the following WebVitalsInstrumentation
class.
initializeFaro({
app: {
instrumentations: [new WebVitalsInstrumentation()],
Session tracking
The session tracking instrumentation reports the change of the session
meta as an event. This is useful for RUM because you can track when a new session starts.
For example, if your application defines a session as the time between login and logout events, the session tracking instrumentation works as follows:
- When the user accesses the application, a session starts
- After the user logs in, another session starts
- When the user logs out, the session changes again
Using the session tracking instrumentation, you can correlate errors, logs, and events that occurred for a particular user during a single session using the application.
In order for the session tracking instrumentation to work correctly, the session
meta should be set accordingly.
How to use the session tracking instrumentation
The following session tracking instrumentation is enabled by default. No additional configuration is required.
initializeFaro({
app: {
instrumentations
array when you initialize the Grafana Faro Web SDK, you must manually include the Session tracking instrumentation.
To manually include the session instrumentation, use the following getWebInstrumentations
helper function.
initializeFaro({
app: {
Alternatively, if you want to fine-tune which instrumentations are enabled, you can use the following SessionInstrumentation
class.
initializeFaro({
app: {
instrumentations: [new SessionInstrumentation()],
View tracking
Note: The view tracking instrumentation is available as of Grafana Faro Web SDK version 1.0.0-beta6.
The view tracking instrumentation reports the change of the view
meta as an event. This is useful for RUM because you can track when a new view is set.
For example, you can set the following different views for an application:
- The register and login pages can be considered
auth
views - The homepage page can be considered a
home
view - The users listing and user profile pages can be seen as
users
views
Using the view tracking instrumentation, you can correlate errors, logs, and events that occurred for a particular user when using a particular section of the application.
In order for the view tracking instrumentation to work correctly, the view
How to use the view tracking instrumentation
The following view tracking instrumentation is enabled by default. No additional configuration is required.
initializeFaro({
app: {
instrumentations
array when you initialize the Grafana Faro Web SDK, you must manually include the View tracking instrumentation.
To manually include the view instrumentation, use the following getWebInstrumentations
helper function.
initializeFaro({
app: {
Alternatively, if you want to fine-tune which instrumentations are enabled, you can use the following ViewInstrumentation
class.
initializeFaro({
app: {
instrumentations: [new ViewInstrumentation()],
Tracing
Tracing collects and reports a detailed view of what occurs each time a user interacts with an application. Because tracing captures an application’s flow and data progression, it yields a considerable amount of data.
The tracing instrumentation performs analysis on the browser of your application. It relies on OpenTelemetry to collect the data and it is leverages the faro.api.pushTraces()
function to report it.
For example, if you have an application with a front end that calls an API that stores data in a database, you can use the tracing instrumentation to:
- Track what happens in your application when the user clicks a button, which APIs are called, how much time is spent on the request, and so on.
- Associate actions that occur in the frontend of your application with actions that occur in the API of your application
- Determine the amount of time spent on specific HTTP requests and the amount of time spent on different events of an HTTP request, for example, domain lookup and so on.
Because tracing produces a lot of data and can compromise application performance, we recommend that you enable it in a production environment only when you need it. You can also enable tracing in a testing environment, or when you want to fine-tune the OpenTelemetry instrumentations.
Do not use tracing:
- If you don’t have a good reason to enable it.
- If your application has an instrumented API. In this case, you can also disable only the
fetch
tracing instrumentation. - If you are not interested in tracing the user interactions, for example, clicks. In this case, you can also disable only the user interaction instrumentation.
By default, tracing uses the following OpenTelemetry instrumentations:
@opentelemetry/instrumentation-document-load
@opentelemetry/instrumentation-fetch
@opentelemetry/instrumentation-user-interaction
@opentelemetry/instrumentation-xml-http-request
Note: To link the traces from the front end with the traces from the API, the tracing instrumentation relies on a trace propagator, which by default uses
W3CTraceContextPropagator
. This propagator adds atraceparent
header to all fetch requests which is then used by your API.
How to use the tracing instrumentation
The following tracing instrumentation is not enabled by default. You must manually enable it.
initializeFaro({
app: {
instrumentations: [
// Other instrumentations
// Don't forget to add the other instrumentations as well
...getWebInstrumentations(),
new TracingInstrumentation({
// Optional, if you want to add custom attributes to the resource
resourceAttributes: {
'my.attribute': 'my-attribute-value',
// Optional, if you want to replace the default W3C Trace Context Propagator
propagator: new MyPropagator(),
// Optional, if you want to overwrite the default Zone Context Manager
contextManager: new MyContextManager(),
// Optional, if you want to overwrite the default instrumentations or set ignore URLs
instrumentations: [
...getDefaultOTELInstrumentations({
// URLs defined here are ignored by the HTTP requests instrumentations
ignoreUrls: [/localhost:3000/],
new MyOtherOTELInstrumentation(),
