Menu
Docker Desktop integration for Grafana Cloud
Docker Desktop is an easy-to-install application for your Mac, Windows or Linux environment that enables you to build and share containerized applications and microservices. This integration allows you to monitor your local Docker Desktop instance using the Grafana Cloud extension in Docker Desktop.The integration includes dashboard to monitor Docker metrics and logs as well as the Linux host metrics and logs.
This integration includes 8 pre-built dashboards to help monitor and visualize Docker Desktop metrics and logs.
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Docker Desktop integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
yaml
integrations:
  prometheus_remote_write:
  - basic_auth:
      password: <your_prom_pass>
      username: <your_prom_user>
    url: <your_prom_url>
  agent:
    enabled: true
    relabel_configs:
    - action: replace
      source_labels:
      - agent_hostname
      target_label: instance
    - action: replace
      target_label: job
    metric_relabel_configs:
    - action: keep
      source_labels:
      - __name__
logs:
  configs:
  - clients:
    - basic_auth:
        password: <your_loki_pass>
        username: <your_loki_user>
      url: <your_loki_url>
    positions:
      filename: /tmp/positions.yaml
    scrape_configs:
metrics:
  configs:
  - name: integrations
    remote_write:
    - basic_auth:
    scrape_configs:
  global:
    scrape_interval: 60s
Dashboards
The Docker Desktop integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
  • Docker Desktop - Docker Logs
  • Docker Desktop - Docker Overview
  • Docker Desktop - Node Exporter / Node CPU and System
  • Docker Desktop - Node Exporter / Node Filesystem and Disk
  • Docker Desktop - Node Exporter / Node Fleet Overview
  • Docker Desktop - Node Exporter / Node Memory
  • Docker Desktop - Node Exporter / Node Network
  • Docker Desktop - Node Exporter / Node Overview
Docker Overview & Compute
Docker Overview &amp; Compute
Docker Logs
Docker Logs
Docker Linux Virtual Machine Overview and Logs
Metrics
The most important metrics provided by the Docker Desktop integration, which are used on the pre-built dashboards, are as follows:
  • container_cpu_usage_seconds_total
  • container_fs_inodes_free
  • container_fs_inodes_total
  • container_fs_limit_bytes
  • container_fs_usage_bytes
  • container_last_seen
  • container_memory_usage_bytes
  • container_network_receive_bytes_total
  • container_network_tcp_usage_total
  • container_network_transmit_bytes_total
  • container_spec_memory_reservation_limit_bytes
  • machine_memory_bytes
  • machine_scrape_error
  • node_arp_entries
  • node_boot_time_seconds
  • node_context_switches_total
  • node_cpu_seconds_total
  • node_disk_io_time_seconds_total
  • node_disk_io_time_weighted_seconds_total
  • node_disk_read_bytes_total
  • node_disk_read_time_seconds_total
  • node_disk_reads_completed_total
  • node_disk_write_time_seconds_total
  • node_disk_writes_completed_total
  • node_disk_written_bytes_total
  • node_filesystem_avail_bytes
  • node_filesystem_device_error
  • node_filesystem_files
  • node_filesystem_files_free
  • node_filesystem_readonly
  • node_filesystem_size_bytes
  • node_intr_total
  • node_load1
  • node_load15
  • node_load5
  • node_memory_Active_anon_bytes
  • node_memory_Active_bytes
  • node_memory_Active_file_bytes
  • node_memory_AnonHugePages_bytes
  • node_memory_AnonPages_bytes
  • node_memory_Bounce_bytes
  • node_memory_Buffers_bytes
  • node_memory_Cached_bytes
  • node_memory_CommitLimit_bytes
  • node_memory_Committed_AS_bytes
  • node_memory_DirectMap1G_bytes
  • node_memory_DirectMap2M_bytes
  • node_memory_DirectMap4k_bytes
  • node_memory_Dirty_bytes
  • node_memory_HugePages_Free
  • node_memory_HugePages_Rsvd
  • node_memory_HugePages_Surp
  • node_memory_HugePages_Total
  • node_memory_Hugepagesize_bytes
  • node_memory_Inactive_anon_bytes
  • node_memory_Inactive_bytes
  • node_memory_Inactive_file_bytes
  • node_memory_Mapped_bytes
  • node_memory_MemAvailable_bytes
  • node_memory_MemFree_bytes
  • node_memory_MemTotal_bytes
  • node_memory_SReclaimable_bytes
  • node_memory_SUnreclaim_bytes
  • node_memory_ShmemHugePages_bytes
  • node_memory_ShmemPmdMapped_bytes
  • node_memory_Shmem_bytes
  • node_memory_SwapTotal_bytes
  • node_memory_VmallocChunk_bytes
  • node_memory_VmallocTotal_bytes
  • node_memory_VmallocUsed_bytes
  • node_memory_WritebackTmp_bytes
  • node_memory_Writeback_bytes
  • node_netstat_Icmp6_InErrors
  • node_netstat_Icmp6_InMsgs
  • node_netstat_Icmp6_OutMsgs
  • node_netstat_Icmp_InErrors
  • node_netstat_Icmp_InMsgs
  • node_netstat_Icmp_OutMsgs
  • node_netstat_IpExt_InOctets
  • node_netstat_IpExt_OutOctets
  • node_netstat_TcpExt_ListenDrops
  • node_netstat_TcpExt_ListenOverflows
  • node_netstat_TcpExt_TCPSynRetrans
  • node_netstat_Tcp_InErrs
  • node_netstat_Tcp_InSegs
  • node_netstat_Tcp_OutRsts
  • node_netstat_Tcp_OutSegs
  • node_netstat_Tcp_RetransSegs
  • node_netstat_Udp6_InDatagrams
  • node_netstat_Udp6_InErrors
  • node_netstat_Udp6_NoPorts
  • node_netstat_Udp6_OutDatagrams
  • node_netstat_Udp6_RcvbufErrors
  • node_netstat_Udp6_SndbufErrors
  • node_netstat_UdpLite_InErrors
  • node_netstat_Udp_InDatagrams
  • node_netstat_Udp_InErrors
  • node_netstat_Udp_NoPorts
  • node_netstat_Udp_OutDatagrams
  • node_netstat_Udp_RcvbufErrors
  • node_netstat_Udp_SndbufErrors
  • node_network_carrier
  • node_network_info
  • node_network_mtu_bytes
  • node_network_receive_bytes_total
  • node_network_receive_compressed_total
  • node_network_receive_drop_total
  • node_network_receive_errs_total
  • node_network_receive_fifo_total
  • node_network_receive_multicast_total
  • node_network_receive_packets_total
  • node_network_speed_bytes
  • node_network_transmit_bytes_total
  • node_network_transmit_compressed_total
  • node_network_transmit_drop_total
  • node_network_transmit_errs_total
  • node_network_transmit_fifo_total
  • node_network_transmit_multicast_total
  • node_network_transmit_packets_total
  • node_network_transmit_queue_length
  • node_network_up
  • node_nf_conntrack_entries
  • node_nf_conntrack_entries_limit
  • node_os_info
  • node_sockstat_FRAG6_inuse
  • node_sockstat_FRAG_inuse
  • node_sockstat_RAW6_inuse
  • node_sockstat_RAW_inuse
  • node_sockstat_TCP6_inuse
  • node_sockstat_TCP_alloc
  • node_sockstat_TCP_inuse
  • node_sockstat_TCP_mem
  • node_sockstat_TCP_mem_bytes
  • node_sockstat_TCP_orphan
  • node_sockstat_TCP_tw
  • node_sockstat_UDP6_inuse
  • node_sockstat_UDPLITE6_inuse
  • node_sockstat_UDPLITE_inuse
  • node_sockstat_UDP_inuse
  • node_sockstat_UDP_mem
  • node_sockstat_UDP_mem_bytes
  • node_sockstat_sockets_used
  • node_softnet_dropped_total
  • node_softnet_processed_total
  • node_softnet_times_squeezed_total
  • node_time_zone_offset_seconds
  • node_timex_estimated_error_seconds
  • node_timex_maxerror_seconds
  • node_timex_offset_seconds
  • node_uname_info
  • node_vmstat_oom_kill
  • node_vmstat_pgfault
  • node_vmstat_pgmajfault
  • node_vmstat_pgpgin
  • node_vmstat_pgpgout
  • node_vmstat_pswpin
  • node_vmstat_pswpout
  • process_max_fds
  • process_open_fds
  • up
Changelog
md
# 1.0.1 - January 2024
* Update mixin to remove deprecated angular panels
# 1.0.0 - September 2023
* Add updated status panels
* Update linux mixin
    * This update introduces 3-tier view of linux nodes:
    * TOP: Fleet view: see group of your linux instances at once
    * Overview of the specific node: see specific node at a glance
    * Drill down: Set of dashboards for deep analysis using advanced metrics (Memory, CPU and System, Filesystem and Disk, Networking)
    * Links and data links are provided for better navigation between views
# 0.0.2 - August 2023
# 0.0.1 - April 2023
* Initial release
Cost
By connecting your Docker Desktop instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
