Apache CouchDB integration for Grafana Cloud
Apache CouchDB is a NoSQL document-oriented database system known for its scalability, availability, and easy replication of data across multiple servers. This integration for Grafana Cloud allows users to collect metrics and system logs for monitoring an Apache CouchDB instance or clustered deployment. This integration also includes useful visualizations for both cluster and node metrics such as open databases, database writes/reads, request latency, request rates, response statuses, and replicator failure info.
This integration supports Apache CouchDB versions 3.2.x+.
This integration includes 10 useful alerts and 3 pre-built dashboards to help monitor and visualize Apache CouchDB metrics and logs.
Before you begin
In order for the integration to properly work, one of two configurations changes must occur. Either a user must be given metric permissions or the unauthenticated Prometheus endpoint must be setup.
Granting metrics permissions to a user
If an admin user and password is not planned on being used in the metric configuration, a CouchDB user must instead be given the _metrics role when creating a new user.
Example
curl http://localhost:5984/_users/org.couchdb.user:prom_user \
-X PUT \
-u admin:password \
-H "Content-Type: application/json" \
-d '{"name":"prom_user", "password":"prom_password", "roles": ["_metrics"], "type": "user"}'Configuring the unauthenticated Prometheus endpoint
To enable the unauthenticated Prometheus endpoint for each node, CouchDB’s configuration file local.ini must be updated to include the correct Prometheus configuration.
Example
[prometheus]
additional_port = true
bind_address = 127.0.0.1
port = 17986Install Apache CouchDB integration for Grafana Cloud
- Find Apache CouchDB and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send Apache CouchDB metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Apache CouchDB setup.
Advanced mode
To instruct Grafana Alloy to scrape your Apache CouchDB instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
discovery.relabel "metrics_integrations_integrations_apache_couchdb" {
targets = concat(
__address__ = "<your-node-hostname1>:5984",
__address__ = "<your-node-hostname2>:5984",
__address__ = "<your-node-hostname3>:5984",
rule {
target_label = "couchdb_cluster"
replacement = "<your-cluster-name>"
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_apache_couchdb" {
targets = discovery.relabel.metrics_integrations_integrations_apache_couchdb.output
job_name = "integrations/apache-couchdb"
metrics_path = "/_node/_local/_prometheus"
basic_auth {
username = "<couchdb_user>"
password = "<couchdb_password>"
}To monitor your Apache CouchDB instance, you must use a discovery.relabel component to discover your Apache CouchDB Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
Configure the following properties within each discovery.relabel component:
__address__: The address to your Apache CouchDB Prometheus metrics endpoint. The ports for the targets should be changed based on if you are using the authenticated endpoint (default5984) or the unauthenticated Prometheus endpoint (default17986).instancelabel:constants.hostnamesets theinstancelabel to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Apache CouchDB instance. Make sure this label value is the same for all telemetry data collected for this instance.couchdb_cluster: Thecouchdb_clusterlabel to group your Apache CouchDB instances within a cluster. Set the same value for all nodes within your cluster.
If you have multiple Apache CouchDB servers to scrape, configure one discovery.relabel for each and scrape them by including each under targets within the prometheus.scrape component.
Beware that the prometheus.scrape component must hold the auth information if your are running an autheticated Prometheus endpoint. Check the component documentation for the different auth options.
Advanced logs snippets
darwin
local.file_match "logs_integrations_integrations_apache_couchdb" {
path_targets = [{
__address__ = "localhost",
__path__ = "/var/log/couchdb/couchdb.log",
couchdb_cluster = "<your-cluster-name>",
instance = constants.hostname,
job = "integrations/apache-couchdb",
loki.process "logs_integrations_integrations_apache_couchdb" {
forward_to = [loki.write.grafana_cloud_loki.receiver]
stage.multiline {
firstline = "\\[[a-z]+\\] \\d+-\\d+-\\d+T\\d+:\\d+:\\d+\\.\\d+"
max_lines = 0
max_wait_time = "3s"
loki.source.file "logs_integrations_integrations_apache_couchdb" {
targets = local.file_match.logs_integrations_integrations_apache_couchdb.targets
forward_to = [loki.process.logs_integrations_integrations_apache_couchdb.receiver]
}To monitor your Apache CouchDB instance logs, you will use a combination of the following components:
- local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__: The Apache CouchDB instance address__path__: The path to the log file.instancelabel:constants.hostnamesets theinstancelabel to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Apache CouchDB instance. Make sure this label value is the same for all telemetry data collected for this instance.couchdb_cluster: Thecouchdb_clusterlabel to group your Apache CouchDB instances within a cluster. Set the same value for all nodes within your cluster.
- loki.process defines how to process logs before sending it to Loki.
- loki.source.file sends logs to Loki.
On Linux, you will also need to add the alloy user to the couchdb group to get logs. Run the following command to configure the user as required:
sudo usermod -a -G couchdb alloylinux
path_targets = [{
stage.multiline {
max_lines = 0
sudo usermod -a -G couchdb alloywindows
path_targets = [{
__path__ = "/Program Files/Apache Software Foundation/CouchDB/var/log/couchdb.log",
stage.multiline {
max_lines = 0
Kubernetes instructions
Before you begin with Kubernetes
Please note: These instructions assume the use of the Kubernetes Monitoring Helm chart
Example
-X PUT \
-u admin:password \
Example
[prometheus]
port = 17986Configuration snippets for Kubernetes Helm chart
To scrape your Apache CouchDB instances, manually modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets <> in the provided snippets with your desired configuration values.
Metrics snippets
alloy-metrics:
extraConfig: |-
discovery.kubernetes "apache_couchdb" {
role = "endpoints"
selectors {
role = "endpoints"
label = "<apache_couchdb_pod_label>=<apache_couchdb_pod_label_value>"
discovery.relabel "apache_couchdb" {
targets = discovery.kubernetes.apache_couchdb.targets
rule {
source_labels = ["__meta_kubernetes_service_name","__meta_kubernetes_endpoint_port_name"]
separator = ":"
regex = ".*-couchdb:metrics"
action = "keep"
rule {
replacement = "<your-couchdb-cluster-name>"
prometheus.scrape "apache_couchdb" {
targets = discovery.relabel.apache_couchdb.output
forward_to = [prometheus.remote_write.grafana_cloud_metrics.receiver]
}Logs snippets
podLogs:
extraDiscoveryRules: |-
rule {
source_labels = ["__meta_kubernetes_namespace","__meta_kubernetes_pod_name","__meta_kubernetes_pod_container_port_name"]
separator = ":"
regex = "sample-apps:.*-couchdb.*:metrics"
replacement = "couchdb"
target_label = "integration"
rule {
source_labels = ["integration","__meta_kubernetes_pod_ip","__meta_kubernetes_pod_container_port_number"]
separator = ":"
regex = "couchdb:(.*):(.*)"
replacement = "$1:$2"
extraLogProcessingStages: |-
stage.match {
selector = "{integration=\\"couchdb\\"}"
stage.static_labels {
values = {
couchdb_cluster = "<your-couchdb-cluster-name>",
log_type = "couchdb",
stage.labels {
values = {
instance = null,
}Dashboards
The Apache CouchDB integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Apache CouchDB logs
- Apache CouchDB nodes
- Apache CouchDB overview
Apache CouchDB overview (1/4)
Apache CouchDB overview (2/4)
Apache CouchDB overview (3/4)
Alerts
The Apache CouchDB integration includes the following useful alerts:
Metrics
The most important metrics provided by the Apache CouchDB integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- couchdb_couch_log_requests_total
- couchdb_couch_replicator_changes_manager_deaths_total
- couchdb_couch_replicator_changes_queue_deaths_total
- couchdb_couch_replicator_changes_reader_deaths_total
- couchdb_couch_replicator_cluster_is_stable
- couchdb_couch_replicator_connection_owner_crashes_total
- couchdb_couch_replicator_connection_worker_crashes_total
- couchdb_couch_replicator_jobs_crashes_total
- couchdb_couch_replicator_jobs_pending
- couchdb_database_reads_total
- couchdb_database_writes_total
- couchdb_erlang_memory_bytes
- couchdb_httpd_bulk_requests
- couchdb_httpd_bulk_requests_total
- couchdb_httpd_request_methods
- couchdb_httpd_status_codes
- couchdb_httpd_temporary_view_reads_total
- couchdb_httpd_view_reads_total
- couchdb_httpd_view_timeouts_total
- couchdb_open_databases
- couchdb_open_databases_total
- couchdb_open_os_files
- couchdb_open_os_files_total
- couchdb_request_time_seconds
- couchdb_request_time_seconds_count
- couchdb_request_time_seconds_sum
- up
Changelog
# 1.1.2 - October 2026
* Fix: Set `job_name` to `integrations/apache-couchdb` in the Kubernetes Helm chart snippet. It was incorrectly set to `integrations/couchdb`, so metrics collected through Kubernetes didn't appear in the Apache CouchDB dashboards and alerts.
* Fix: Set the `job` log label to `integrations/apache-couchdb` in the Kubernetes Helm chart snippet. It was incorrectly set to `integrations/apache-cassandra`, so logs collected through Kubernetes didn't appear in the Apache CouchDB dashboards.
# 1.1.1 - June 2026
* Fixed issue with default filtering selectors
# 1.1.0 - April 2026
* Updated dashboards to follow new stylistic standards
* Renamed alert `CouchDBReplicatorConnectionOwnersCrashing` to `CouchDBReplicatorOwnersCrashing`
* Renamed alert `CouchDBReplicatorConnectionWorkersCrashing` to `CouchDBReplicatorWorkersCrashing`
* Added logs dashboard `Apache CouchDB logs`
# 1.0.0 - May 2024
* Added cluster selector to dashboards for kubernetes support
* Added default cluster label to agent config
* Bump version to 1.0.0
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - April 2023
* Initial releaseCost
By connecting your Apache CouchDB instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
