title: "Reduce Grafana Cloud IRM costs | Grafana Cloud documentation"
description: "Reduce your Grafana Cloud IRM costs."
# Reduce Grafana Cloud IRM costs
You can reduce Grafana Cloud Incident Response &amp; Management (IRM) costs by limiting how many monthly active IRM users your organization uses each month. Refer to [Understand your Grafana Cloud IRM invoice](/docs/grafana-cloud/cost-management-and-billing/manage-invoices/understand-your-invoice/irm-invoice/) for how monthly active IRM users are measured and billed.
## Review your usage
Review IRM usage before you change schedules or escalation chains so you can see which users drive monthly active user counts.
You can review usage on the [Billing and Usage dashboard](/docs/grafana-cloud/cost-management-and-billing/manage-invoices/understand-your-invoice/#billing-and-usage-dashboard) on the IRM usage panels. You can also open **Cost Management and Billing** &gt; **Usage** and select **IRM** for usage trends and cost details. Refer to [Monitor usage](/docs/grafana-cloud/cost-management-and-billing/understand-usage-cost/).
You can configure [usage and cost alerts](/docs/grafana-cloud/cost-management-and-billing/usage-cost-alerts/) or [billing usage alerts](/docs/grafana-cloud/cost-management-and-billing/set-up-usage-alerts/) from the Billing and Usage dashboard to notify your team when IRM usage exceeds expected levels.
## Understand billable usage
An active IRM user is someone who meets any of the following criteria during the calendar month:
- Is included in an OnCall schedule or escalation chain
- Changes the status of an alert group or OnCall configuration
- Receives a page or pages another user
- Creates, edits, or updates an incident
> Note
> Being listed in a schedule or escalation chain can make a user billable for the month, even if they do not respond to alerts. Review schedules and chains regularly to avoid paying for users who no longer participate in on-call.
Monthly active user counts reset at the start of each calendar month.
## Reduce your usage
The most effective ways to control IRM costs focus on who is configured to respond—not on how many alerts you receive.
### Limit users in on-call schedules
On-call schedules define who can be paged when escalation chains run. Each user assigned to a schedule can count toward monthly active users.
To reduce billable users:
- Remove users who no longer participate in on-call from schedules and rotations.
- Use the smallest rotation pool that still meets coverage needs. For example, a weekly rotation with three engineers over listing every engineer on the team.
- Use [user groups in rotations](/docs/irm/on-call-schedules/) when multiple people cover the same shift, instead of adding duplicate individual users across overlapping schedules.
- Review [imported schedules](/docs/irm/on-call-schedules/import-schedules/) and external calendars for stale entries that still include former team members.
Refer to [Best practices for on-call schedules](/docs/irm/guides/best-practices/schedules/) for rotation design and coverage quality.
### Streamline escalation chains
Escalation chains determine who is notified when alerts fire. Users referenced in escalation steps can count as active even if they are rarely paged.
- Replace **Notify all team members** steps with **Notify from on-call schedule** or **Notify users** steps that target only current responders.
- Prefer **Notify users one by one (round robin)** over notifying a large fixed list on every alert group.
- Avoid **Notify next on-call shift from Schedule** unless you need to page everyone in the upcoming shift. This step notifies all users in the next shift when parallel slots or layers exist.
- Use **Notify all Slack channel members** and **Notify Slack user group** steps with care. These steps can notify many people and increase the chance that additional users become active when they acknowledge or respond to alerts.
- Remove users from escalation chains when they leave the team or move to a non-on-call role.
Refer to [Configure escalation chains](/docs/irm/escalation-and-routing/escalation-chains/) and [Escalation chains best practices](/docs/irm/guides/best-practices/escalation-chains/).
### Reduce incidental active usage
Users can also become active when they change OnCall or alert group status, page others, or work in incidents.
To limit this usage:
- Use [IRM roles and permissions](/docs/irm/set-up/manage-access/roles-and-permissions/) to limit who can edit escalation chains, schedules, and integrations. For example, reserve **Escalation Chains Editor** and **Schedules Editor** roles for administrators or a small operations group.
- Limit **Alert Groups Direct Paging** to users who must manually page responders, instead of granting it broadly across the organization.
- Use a consistent incident workflow so only responders who own the incident create or update incident records.
- Train teams to page through defined escalation chains rather than using direct paging for broad groups of users.
