This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/cost-management-and-billing/analyze-costs/reduce-costs/frontend-observability-costs.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/cost-management-and-billing/analyze-costs/reduce-costs/frontend-observability-costs/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Reduce Grafana Cloud Frontend Observability costs
Control your Frontend Observability costs by managing the number of sessions you track and the volume of logs and traces your application sends.
Grafana Cloud Frontend Observability usage is measured in three dimensions: sessions, logs, and traces. Sessions are the primary cost driver, as each session also generates logs and trace data. Reducing the number of sessions also reduces log and trace generation. You can also reduce logs and traces independently by limiting what your application instruments and sends. The Adaptive Telemetry features can also be used to filter logs and traces that are not being used in dashboards, alert rules, or recent Explore queries.
For more details about how Frontend Observability usage is calculated, refer to Understand your Grafana Cloud Frontend Observability invoice.
Review your usage
You can review your Frontend Observability usage in the Usage tab of the Cost Management and Billing app. Configure usage and cost alerts to notify your team when activity exceeds expected levels.
Reduce your session volume
Sessions are the primary billable unit in Frontend Observability. Reducing session volume lowers costs and also reduces the logs and traces generated per session.
Use sampling
Faro makes sampling decisions on a per-session basis. For sampled sessions, Faro collects and transmits all signals. If a session is not sampled, Faro discards all signals.
Setting a sampling rate lower than 1 (100%) reduces the number of billable sessions and the telemetry generation.
For example, a sampling rate of 0.5 tracks 50% of user sessions, which halves session costs and reduces logs and trace volume proportionally.
initializeFaro({
sessionTracking: {
samplingRate: 0.5,
});You can also define a custom sampler function to apply different sampling rates based on user attributes, application state, or other context. For example, you can sample a higher proportion of users in a specific region or reduce sampling during off-peak hours.
Refer to Configure sampling in Faro for configuration details and examples.
Reduce log volume
Browser logs contribute to your logs usage. You can reduce log volume by limiting what your application sends to Grafana Cloud.
Disable or limit console instrumentation
Faro captures console.error, console.warn, and console.info output by default.
The more verbose levels (console.debug, console.trace, and console.log) are already disabled by default.
If you don’t need console logs at all, disable the instrumentation entirely using captureConsole: false.
If you need some console output, enable only the levels that provide diagnostic value and leave the rest disabled.
initializeFaro({
instrumentations: [
...getWebInstrumentations({
captureConsole: false,
});Refer to Console instrumentation for configuration options.
Drop signals before sending
Use the beforeSend hook to inspect and discard specific signals before Faro transmits them.
Returning null from the hook drops the item entirely, which lets you filter out high-volume or low-value signals without disabling entire instrumentations.
For example, to suppress all logs:
initializeFaro({
beforeSend: (item) => {
if (item.type === 'log') {
return null;
return item;
});Refer to Modify beacon data before send for details and examples.
Reduce trace volume
Client-side traces contribute to your traces usage. You can reduce trace volume by limiting what your application instruments and which URLs it tracks.
Exclude third-party endpoints
By default, Faro’s performance instrumentation captures all resource entries, including requests to third-party services such as analytics platforms or content delivery networks. These requests often add trace volume without providing useful observability data.
Use the ignoreUrls property to exclude URLs from performance tracking:
initializeFaro({
ignoreUrls: [/.*.analytics.vendor.com.*/, 'https://other-analytics.com/foo'],
});Refer to Exclude endpoints from tracking for configuration details.
Disable tracing instrumentation
If you don’t use client-side traces, you can remove the tracing package from your Faro initialization entirely.
Traces are only collected when you include the @grafana/faro-web-tracing package and add a tracing instrumentation.
If you added tracing during initial setup but don’t use trace data in your workflows, removing the tracing instrumentation eliminates all client-side trace volume.
Filter bot traffic
Automated traffic from bots and crawlers generates sessions and telemetry without representing real user activity. Excluding bot traffic reduces session counts and the logs and traces associated with them.
Refer to Filter bots for details on how to exclude bot sessions from tracking.
Was this page helpful?
