title: "Multi-organization and headers | Grafana Cloud documentation"
description: "Target a specific Grafana organization and send custom HTTP headers from the MCP server."
# Multi-organization and headers
You can point the server at a specific Grafana organization and add custom HTTP headers to every request to Grafana.
## What you’ll achieve
All Grafana API calls use the chosen organization context, and any extra headers you need (for example, tenant or custom auth) are sent automatically.
## Before you begin
- A Grafana instance with multiple organizations (or a need for custom headers).
- The server configured with [Authentication](/docs/grafana-cloud/ai-tools/mcp-servers/oss-mcp/configure/authentication).
## Set the organization
Set **GRAFANA\_ORG\_ID** to the numeric organization ID. The server sends `X-Grafana-Org-Id` on all requests to Grafana.
When using SSE or streamable-http, you can also send **X-Grafana-Org-Id** from the client; the header takes precedence over the environment variable so you can override the default org per request.
## Send custom headers
Set **GRAFANA\_EXTRA\_HEADERS** to a JSON object mapping header names to values. These headers are added to every Grafana API request.
Example:
JSON ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```json
"GRAFANA_EXTRA_HEADERS": "{\"X-Custom-Header\": \"value\", \"X-Tenant-ID\": \"tenant-123\"}"
## Next steps
- [Authentication](/docs/grafana-cloud/ai-tools/mcp-servers/oss-mcp/configure/authentication) for Grafana credentials.
- [Enable and disable tools](/docs/grafana-cloud/ai-tools/mcp-servers/oss-mcp/configure/enable-and-disable-tools) to limit which tools are available.
