title: "OpenTelemetry to Grafana stack | Grafana Agent documentation"
description: "Learn how to collect OpenTelemetry data and forward it to the Grafana stack"
# OpenTelemetry to Grafana stack
You can configure Grafana Agent Flow to collect [OpenTelemetry](https://opentelemetry.io)-compatible data and forward it to the Grafana stack.
This topic describes how to:
- Configure Grafana Agent Flow to send your data to Loki.
- Configure Grafana Agent Flow to send your data to Tempo.
- Configure Grafana Agent Flow to send your data to Mimir or Prometheus Remote Write.
## Components used in this topic
- [loki.write](/docs/agent/v0.43/flow/reference/components/loki.write/)
- [otelcol.auth.basic](/docs/agent/v0.43/flow/reference/components/otelcol.auth.basic/)
- [otelcol.exporter.loki](/docs/agent/v0.43/flow/reference/components/otelcol.exporter.loki/)
- [otelcol.exporter.otlp](/docs/agent/v0.43/flow/reference/components/otelcol.exporter.otlp/)
- [otelcol.exporter.prometheus](/docs/agent/v0.43/flow/reference/components/otelcol.exporter.prometheus/)
- [otelcol.processor.batch](/docs/agent/v0.43/flow/reference/components/otelcol.processor.batch/)
- [otelcol.receiver.otlp](/docs/agent/v0.43/flow/reference/components/otelcol.receiver.otlp/)
- [prometheus.remote\_write](/docs/agent/v0.43/flow/reference/components/prometheus.remote_write/)
## Before you begin
- Ensure that you have basic familiarity with instrumenting applications with OpenTelemetry.
- Have a set of OpenTelemetry applications ready to push telemetry data to Grafana Agent Flow.
- Identify where Grafana Agent Flow will write received telemetry data.
- Be familiar with the concept of [Components](/docs/agent/v0.43/flow/concepts/components/) in Grafana Agent Flow.
- Complete the [Collect open telemetry data](/docs/agent/v0.43/flow/tasks/collect-opentelemetry-data/) task. You will pick up from where that guide ended.
## The pipeline
You can start with the Grafana Agent Flow configuration you created in the [Collect open telemetry data](/docs/agent/v0.43/flow/tasks/collect-opentelemetry-data/) task.
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
otelcol.receiver.otlp "example" {
  grpc {
    endpoint = "127.0.0.1:4317"
  http {
    endpoint = "127.0.0.1:4318"
  output {
    metrics = [otelcol.processor.batch.example.input]
    logs    = [otelcol.processor.batch.example.input]
    traces  = [otelcol.processor.batch.example.input]
otelcol.processor.batch "example" {
  output {
    metrics = [otelcol.exporter.otlp.default.input]
    logs    = [otelcol.exporter.otlp.default.input]
    traces  = [otelcol.exporter.otlp.default.input]
otelcol.exporter.otlp "default" {
  client {
    endpoint = "my-otlp-grpc-server:4317"
The pipeline currently looks like this:
```none
Metrics, Logs, Traces: OTLP Receiver → batch processor → OTLP Exporter
You will implement the following pipelines to send your data to Loki, Tempo, and Mimir or Prometheus.
```none
Metrics: OTel → batch processor → Mimir or Prometheus remote write
Logs: OTel → batch processor → Loki exporter
Traces: OTel → batch processor → OTel exporter
## Grafana Loki
[Grafana Loki](/oss/loki/) is a horizontally scalable, highly available, multi-tenant log aggregation system inspired by Prometheus. Similar to Prometheus, to send from OTLP to Loki, you can do a passthrough from the [otelcol.exporter.loki](/docs/agent/v0.43/flow/reference/components/otelcol.exporter.loki/) component to [loki.write](/docs/agent/v0.43/flow/reference/components/loki.write/) component.
```alloy
otelcol.exporter.loki "default" {
	forward_to = [loki.write.default.receiver]
loki.write "default" {
	endpoint {
		url = "http://loki-endpoint:8080/loki/api/v1/push"
To use Loki with basic-auth, which is required with Grafana Cloud Loki, you must configure the [loki.write](/docs/agent/v0.43/flow/reference/components/loki.write/) component. You can get the Loki configuration from the Loki **Details** page in the [Grafana Cloud Portal](/docs/grafana-cloud/account-management/cloud-portal/#your-grafana-cloud-stack):
```alloy
otelcol.exporter.loki "grafana_cloud_loki" {
	forward_to = [loki.write.grafana_cloud_loki.receiver]
loki.write "grafana_cloud_loki" {
	endpoint {
		url = "https://logs-prod-us-central1.grafana.net/loki/api/v1/push"
		basic_auth {
			username = 5252
			password = env("GRAFANA_CLOUD_API_KEY")
## Grafana Tempo
[Grafana Tempo](/oss/tempo/) is an open source, easy-to-use, scalable distributed tracing backend. Tempo can ingest OTLP directly, and you can use the OTLP exporter to send the traces to Tempo.
```alloy
  client {
    endpoint = "tempo-server:4317"
To use Tempo with basic-auth, which is required with Grafana Cloud Tempo, you must use the [otelcol.auth.basic](/docs/agent/v0.43/flow/reference/components/otelcol.auth.basic/) component. You can get the Tempo configuration from the Tempo **Details** page in the [Grafana Cloud Portal](/docs/grafana-cloud/account-management/cloud-portal/#your-grafana-cloud-stack):
```alloy
otelcol.exporter.otlp "grafana_cloud_tempo" {
	client {
		endpoint = "tempo-us-central1.grafana.net:443"
		auth     = otelcol.auth.basic.grafana_cloud_tempo.handler
otelcol.auth.basic "grafana_cloud_tempo" {
	username = 4094
## Grafana Mimir or Prometheus Remote Write
[Prometheus Remote Write](https://prometheus.io/docs/operating/integrations/#remote-endpoints-and-storage) is a popular metrics transmission protocol supported by most metrics systems, including [Grafana Mimir](/oss/mimir/) and Grafana Cloud. To send from OTLP to Prometheus, you can do a passthrough from the [otelcol.exporter.prometheus](/docs/agent/v0.43/flow/reference/components/otelcol.exporter.prometheus/) to the [prometheus.remote\_write](/docs/agent/v0.43/flow/reference/components/prometheus.remote_write/) component. The Prometheus remote write component in Grafana Agent Flow is a robust protocol implementation, including a Write Ahead Log (WAL) for resiliency.
```alloy
otelcol.exporter.prometheus "default" {
	forward_to = [prometheus.remote_write.default.receiver]
prometheus.remote_write "default" {
	endpoint {
		url = "http://prometheus:9090/api/v1/write"
To use Prometheus with basic-auth, which is required with Grafana Cloud Prometheus, you must configure the [prometheus.remote\_write](/docs/agent/v0.43/flow/reference/components/prometheus.remote_write/) component. You can get the Prometheus configuration from the Prometheus **Details** page in the [Grafana Cloud Portal](/docs/grafana-cloud/account-management/cloud-portal/#your-grafana-cloud-stack):
```alloy
otelcol.exporter.prometheus "grafana_cloud_prometheus" {
        forward_to = [prometheus.remote_write.grafana_cloud_prometheus.receiver]
prometheus.remote_write "grafana_cloud_prometheus" {
    endpoint {
        url = "https://prometheus-us-central1.grafana.net/api/prom/push"
        basic_auth {
            username = 12690
## Putting it all together
Instead of referencing `otelcol.exporter.otlp.default.input` in the output of `otelcol.processor.batch`, you need to reference the three exporters you set up. The final configuration becomes:
```alloy
  grpc {
  http {
  output {
  output {
    metrics = [otelcol.exporter.prometheus.grafana_cloud_prometheus.input]
    logs    = [otelcol.exporter.loki.grafana_cloud_loki.input]
    traces  = [otelcol.exporter.otlp.grafana_cloud_tempo.input]
	client {
	username = 4094
    endpoint {
        basic_auth {
            username = 12690
	endpoint {
		basic_auth {
			username = 5252
Running Grafana Agent Flow now will give you the following:
```none
AGENT_MODE=flow ./grafana-agent run agent-config.river
ts=2023-05-09T09:37:15.300959Z level=info msg="running usage stats reporter"
ts=2023-05-09T09:37:15.300958Z level=info msg="now listening for http traffic" addr=127.0.0.1:12345
ts=2023-05-09T09:37:15.301104Z level=info trace_id=6466516c9e1a556422df7a84c0ade6b0 msg="starting complete graph evaluation"
ts=2023-05-09T09:37:15.301307Z level=info trace_id=6466516c9e1a556422df7a84c0ade6b0 msg="finished node evaluation" node_id=loki.write.grafana_cloud_loki duration=188.209µs
ts=2023-05-09T09:37:15.301334Z level=info trace_id=6466516c9e1a556422df7a84c0ade6b0 msg="finished node evaluation" node_id=otelcol.exporter.loki.grafana_cloud_loki duration=18.791µs
ts=2023-05-09T09:37:15.303138Z component=prometheus.remote_write.grafana_cloud_prometheus level=info subcomponent=wal msg="replaying WAL, this may take a while" dir=data-agent/prometheus.remote_write.grafana_cloud_prometheus/wal
ts=2023-05-09T09:37:15.303257Z component=prometheus.remote_write.grafana_cloud_prometheus level=info subcomponent=wal msg="WAL segment loaded" segment=0 maxSegment=1
ts=2023-05-09T09:37:15.303302Z component=prometheus.remote_write.grafana_cloud_prometheus level=info subcomponent=wal msg="WAL segment loaded" segment=1 maxSegment=1
ts=2023-05-09T09:37:15.303507Z component=prometheus.remote_write.grafana_cloud_prometheus subcomponent=rw level=info remote_name=7f623a url=https://prometheus-us-central1.grafana.net/api/prom/push msg="Starting WAL watcher" queue=7f623a
ts=2023-05-09T09:37:15.303515Z component=prometheus.remote_write.grafana_cloud_prometheus subcomponent=rw level=info remote_name=7f623a url=https://prometheus-us-central1.grafana.net/api/prom/push msg="Starting scraped metadata watcher"
ts=2023-05-09T09:37:15.303522Z level=info trace_id=6466516c9e1a556422df7a84c0ade6b0 msg="finished node evaluation" node_id=prometheus.remote_write.grafana_cloud_prometheus duration=2.181958ms
ts=2023-05-09T09:37:15.303557Z level=info trace_id=6466516c9e1a556422df7a84c0ade6b0 msg="finished node evaluation" node_id=otelcol.exporter.prometheus.grafana_cloud_prometheus duration=30.083µs
ts=2023-05-09T09:37:15.303611Z component=prometheus.remote_write.grafana_cloud_prometheus subcomponent=rw level=info remote_name=7f623a url=https://prometheus-us-central1.grafana.net/api/prom/push msg="Replaying WAL" queue=7f623a
ts=2023-05-09T09:37:15.303618Z level=info trace_id=6466516c9e1a556422df7a84c0ade6b0 msg="finished node evaluation" node_id=otelcol.auth.basic.grafana_cloud_tempo duration=52.5µs
ts=2023-05-09T09:37:15.303694Z level=info trace_id=6466516c9e1a556422df7a84c0ade6b0 msg="finished node evaluation" node_id=otelcol.exporter.otlp.grafana_cloud_tempo duration=70.375µs
ts=2023-05-09T09:37:15.303782Z component=otelcol.processor.memory_limiter.default level=info msg="Memory limiter configured" limit_mib=150 spike_limit_mib=30 check_interval=1s
ts=2023-05-09T09:37:15.303802Z level=info trace_id=6466516c9e1a556422df7a84c0ade6b0 msg="finished node evaluation" node_id=otelcol.processor.memory_limiter.default duration=100.334µs
ts=2023-05-09T09:37:15.303853Z level=info trace_id=6466516c9e1a556422df7a84c0ade6b0 msg="finished node evaluation" node_id=otelcol.processor.batch.default duration=44.75µs
ts=2023-05-09T09:37:15.303948Z level=info trace_id=6466516c9e1a556422df7a84c0ade6b0 msg="finished node evaluation" node_id=otelcol.receiver.otlp.default duration=87.333µs
ts=2023-05-09T09:37:15.303968Z level=info trace_id=6466516c9e1a556422df7a84c0ade6b0 msg="finished node evaluation" node_id=tracing duration=10.792µs
ts=2023-05-09T09:37:15.303981Z level=info trace_id=6466516c9e1a556422df7a84c0ade6b0 msg="finished node evaluation" node_id=logging duration=9µs
ts=2023-05-09T09:37:15.303987Z level=info trace_id=6466516c9e1a556422df7a84c0ade6b0 msg="finished complete graph evaluation" duration=2.960333ms
ts=2023-05-09T09:37:15.304Z level=info msg="scheduling loaded components"
ts=2023-05-09T09:37:15.304109Z component=otelcol.receiver.otlp.default level=info msg="Starting GRPC server" endpoint=0.0.0.0:4317
ts=2023-05-09T09:37:15.304234Z component=otelcol.receiver.otlp.default level=info msg="Starting HTTP server" endpoint=0.0.0.0:4318
You can now check the pipeline graphically by visiting [http://localhost:12345/graph](http://localhost:12345/graph)
