Caution
Grafana Agent has reached End-of-Life (EOL) on November 1, 2025. Agent is no longer receiving vendor support and will no longer receive security or bug fixes. Current users of Agent Static mode, Agent Flow mode, and Agent Operator should proceed with migrating to Grafana Alloy. If you have already migrated to Alloy, no further action is required. Read more about why we recommend migrating to Grafana Alloy.
Collect OpenTelemetry data
Grafana Agent Flow can be configured to collect OpenTelemetry-compatible data and forward it to any OpenTelemetry-compatible endpoint.
This topic describes how to:
- Configure OpenTelemetry data delivery.
- Configure batching.
- Receive OpenTelemetry data over OTLP.
Components used in this topic
- otelcol.auth.basic
- otelcol.exporter.otlp
- otelcol.exporter.otlphttp
- otelcol.processor.batch
- otelcol.receiver.otlp
Before you begin
- Ensure that you have basic familiarity with instrumenting applications with OpenTelemetry.
- Have a set of OpenTelemetry applications ready to push telemetry data to Grafana Agent Flow.
- Identify where Grafana Agent Flow writes received telemetry data.
- Be familiar with the concept of Components in Grafana Agent Flow.
Configure an OpenTelemetry Protocol exporter
Before components can receive OpenTelemetry data, you must have a component responsible for exporting the OpenTelemetry data. An OpenTelemetry exporter component is responsible for writing (exporting) OpenTelemetry data to an external system.
In this task, you will use the otelcol.exporter.otlp component to send OpenTelemetry data to a server using the OpenTelemetry Protocol (OTLP). After an exporter component is defined, you can use other Grafana Agent Flow components to forward data to it.
Refer to the list of available Components for the full list of
otelcol.exportercomponents that you can use to export OpenTelemetry data.
To configure an otelcol.exporter.otlp component for exporting OpenTelemetry data using OTLP, complete the following steps:
Add the following
otelcol.exporter.otlpcomponent to your configuration file:otelcol.exporter.otlp "<EXPORTER_LABEL>" { client { url = "<HOST>:<PORT>" } }Replace the following:
<EXPORTER_LABEL>: The label for the component, such asdefault. The label you use must be unique across allotelcol.exporter.otlpcomponents in the same configuration file.
<HOST>: The hostname or IP address of the server to send OTLP requests to.
<PORT>: The port of the server to send OTLP requests to.
If your server requires basic authentication, complete the following:
Add the following
otelcol.auth.basiccomponent to your configuration file:otelcol.auth.basic "<BASIC_AUTH_LABEL>" { username = "<USERNAME>" password = "<PASSWORD>" }Replace the following:
<BASIC_AUTH_LABEL>: The label for the component, such asdefault. The label you use must be unique across allotelcol.auth.basiccomponents in the same configuration file.<USERNAME>: The basic authentication username.<PASSWORD>: The basic authentication password or API key.
Add the following line inside of the
clientblock of yourotelcol.exporter.otlpcomponent:auth = otelcol.auth.basic.<BASIC_AUTH_LABEL>.handlerReplace the following:
<BASIC_AUTH_LABEL>: The label for theotelcol.auth.basiccomponent.
If you have more than one server to export metrics to, create a new
otelcol.exporter.otlpcomponent for each additional server.
otelcol.exporter.otlpsends data using OTLP over gRPC (HTTP/2). To send to a server using HTTP/1.1, follow the preceding steps, but use the otelcol.exporter.otlphttp component instead.
The following example demonstrates configuring otelcol.exporter.otlp with authentication and a component that forwards data to it:
otelcol.exporter.otlp "default" {
client {
endpoint = "my-otlp-grpc-server:4317"
auth = otelcol.auth.basic.credentials.handler
otelcol.auth.basic "credentials" {
// Retrieve credentials using environment variables.
username = env("BASIC_AUTH_USER")
password = env("API_KEY")
otelcol.receiver.otlp "example" {
grpc {
endpoint = "127.0.0.1:4317"
http {
endpoint = "127.0.0.1:4318"
output {
metrics = [otelcol.exporter.otlp.default.input]
logs = [otelcol.exporter.otlp.default.input]
traces = [otelcol.exporter.otlp.default.input]
}For more information on writing OpenTelemetry data using the OpenTelemetry Protocol, refer to otelcol.exporter.otlp.
Configure batching
Production-ready Grafana Agent Flow configurations shouldn’t send OpenTelemetry data directly to an exporter for delivery. Instead, data is usually sent to one or more processor components that perform various transformations on the data.
Ensuring data is batched is a production-readiness step to improve data compression and reduce the number of outgoing network requests to external systems.
In this task, you will configure an otelcol.processor.batch component to batch data before sending it to the exporter.
otelcol.processorcomponents that you can use to process OpenTelemetry data. You can chain processors by having one processor send data to another processor.
To configure an otelcol.processor.batch component, complete the following steps:
Follow Configure an OpenTelemetry Protocol exporter to ensure received data can be written to an external system.
Add the following
otelcol.processor.batchcomponent into your configuration file:otelcol.processor.batch "<PROCESSOR_LABEL>" { output { metrics = [otelcol.exporter.otlp.<EXPORTER_LABEL>.input] logs = [otelcol.exporter.otlp.<EXPORTER_LABEL>.input] traces = [otelcol.exporter.otlp.>EXPORTER_LABEL>.input] } }Replace the following:
<PROCESSOR_LABEL>: The label for the component, such asdefault. The label you use must be unique across allotelcol.processor.batchcomponents in the same configuration file.<EXPORTER_LABEL>: The label for your existingotelcol.exporter.otlpcomponent.
To disable one of the telemetry types, set the relevant type in the
outputblock to the empty list, such asmetrics = [].To send batched data to another processor, replace the components in the
outputlist with the processor components to use.
The following example demonstrates configuring a sequence of otelcol.processor components before being exported.
otelcol.processor.memory_limiter "default" {
check_interval = "1s"
limit = "1GiB"
output {
metrics = [otelcol.processor.batch.default.input]
logs = [otelcol.processor.batch.default.input]
traces = [otelcol.processor.batch.default.input]
otelcol.processor.batch "default" {
output {
client {
}For more information on configuring OpenTelemetry data batching, refer to otelcol.processor.batch.
Configure an OpenTelemetry Protocol receiver
You can configure Grafana Agent Flow to receive OpenTelemetry metrics, logs, and traces. An OpenTelemetry receiver component is responsible for receiving OpenTelemetry data from an external system.
In this task, you will use the otelcol.receiver.otlp component to receive OpenTelemetry data over the network using the OpenTelemetry Protocol (OTLP). You can configure a receiver component to forward received data to other Grafana Agent Flow components.
otelcol.receivercomponents that you can use to receive OpenTelemetry-compatible data.
To configure an otelcol.receiver.otlp component for receiving OTLP data, complete the following steps:
Optional: Follow Configure batching to improve compression and reduce the total amount of network requests.
Add the following
otelcol.receiver.otlpcomponent to your configuration file.otelcol.receiver.otlp "<LABEL>" { output { metrics = [<COMPONENT_INPUT_LIST>] logs = [<COMPONENT_INPUT_LIST>] traces = [<COMPONENT_INPUT_LIST>] } }Replace the following:
<LABEL>: The label for the component, such asdefault. The label you use must be unique across allotelcol.receiver.otlpcomponents in the same configuration file.<COMPONENT_INPUT_LIST>: A comma-delimited list of component inputs to forward received data to. For example, to send data to an existing batch processor component, useotelcol.processor.batch.PROCESSOR_LABEL.input. To send data directly to an existing exporter component, useotelcol.exporter.otlp.EXPORTER_LABEL.input.
To allow applications to send OTLP data over gRPC on port
4317, add the following to yourotelcol.receiver.otlpcomponent.grpc { endpoint = "<HOST>:4317" }Replace the following:
<HOST>: A host to listen to traffic on. Use a narrowly scoped listen address whenever possible. To listen on all network interfaces, replace<HOST>with0.0.0.0.
To allow applications to send OTLP data over HTTP/1.1 on port
4318, add the following to yourotelcol.receiver.otlpcomponent.http { endpoint = "<HOST>:4318" }Replace the following:
<HOST>: The host to listen to traffic on. Use a narrowly scoped listen address whenever possible. To listen on all network interfaces, replace<HOST>with0.0.0.0.
The following example demonstrates configuring otelcol.receiver.otlp and sending it to an exporter:
grpc {
http {
output {
metrics = [otelcol.processor.batch.example.input]
logs = [otelcol.processor.batch.example.input]
traces = [otelcol.processor.batch.example.input]
otelcol.processor.batch "example" {
output {
client {
}For more information on receiving OpenTelemetry data using the OpenTelemetry Protocol, refer to otelcol.receiver.otlp.
