Add field override support to panel plugins
Field overrides allow your users to customize how individual fields are displayed in a dashboard panel. For example, you can change the unit of a single series, apply a different color to one field, or set custom thresholds for a specific column in a table.
This guide shows you how to enable field overrides in your panel plugin, customize which standard options are available, and define your own custom field configuration properties.
Prerequisites​
- A Grafana panel plugin with a
module.tsentry point - Familiarity with TypeScript and the
PanelPluginAPI
For a step-by-step guide to building a panel plugin from scratch, refer to the Build a panel plugin tutorial.
How field overrides work​
Grafana's field configuration system has two layers:
- Defaults apply to every field in the panel. Users set these in the panel editor options pane, where standard properties appear under sections such as Standard options, Thresholds, Value mappings, and Data links and actions, and custom properties appear under the categories your plugin defines.
- Overrides apply only to fields that match a specific rule. Users add these with the Add field override button at the bottom of the panel editor options pane. Each rule has a matcher (which fields to target) and one or more properties (what to change).
Grafana applies defaults first, then applies matching override rules on top in order. Later rules take precedence over earlier ones.
Users can match fields by exact name, by regular expression, by field type, by the query that returned them, or by field values (for example, all fields whose values are null).
Enable field configuration​
Call useFieldConfig() on your PanelPlugin instance in module.ts to enable all standard field configuration properties (unit, decimals, thresholds, color, value mappings, data links, and others). This makes them available in the panel editor both as defaults and as overrides.
import { PanelPlugin } from '@grafana/data';
import { SimplePanel } from './SimplePanel';
import { Options } from './types';
export const plugin = new PanelPlugin<Options>(SimplePanel).useFieldConfig();
With this single call, users of your panel can set default values for all standard properties and add override rules that target specific fields.
Customize standard options​
Pass a configuration object to useFieldConfig() to customize which standard properties are available and what their defaults are.
Set default values​
Use standardOptions to change the default value of any standard property:
import { FieldConfigProperty, PanelPlugin } from '@grafana/data';
export const plugin = new PanelPlugin<Options>(SimplePanel).useFieldConfig({
standardOptions: {
[FieldConfigProperty.Decimals]: {
defaultValue: 2,
[FieldConfigProperty.Unit]: {
defaultValue: 'percent',
Disable standard options​
If certain properties don't make sense for your visualization, remove them with disableStandardOptions. This hides the property from both the defaults panel and the override property picker:
disableStandardOptions: [FieldConfigProperty.Thresholds, FieldConfigProperty.Mappings],
Configure standard option settings​
Some standard options accept additional settings that control their behavior. For example, the color option supports different color modes:
import { FieldColorModeId, FieldConfigProperty, PanelPlugin } from '@grafana/data';
standardOptions: {
[FieldConfigProperty.Color]: {
settings: {
byValueSupport: true,
bySeriesSupport: true,
preferThresholdsMode: false,
defaultValue: {
mode: FieldColorModeId.PaletteClassic,
Each standardOptions entry also accepts hideFromDefaults: true, which hides the property from the defaults section of the options pane while keeping it available in override rules.
Add custom field configuration properties​
You can define custom properties specific to your visualization beyond the standard ones. These appear alongside the standard options in the panel editor and are available as override properties.
Define the custom field config type​
Start by defining a TypeScript interface for your custom field configuration:
export interface FieldConfig {
lineWidth: number;
fillOpacity: number;
showPoints: boolean;
export const defaultFieldConfig: FieldConfig = {
lineWidth: 1,
fillOpacity: 10,
showPoints: false,
Register custom properties​
Pass your custom field config type as the second generic parameter to PanelPlugin and use the useCustomConfig callback to register each property with the builder:
import { FieldConfig, Options, defaultFieldConfig } from './types';
export const plugin = new PanelPlugin<Options, FieldConfig>(SimplePanel).useFieldConfig({
useCustomConfig: (builder) => {
builder
.addSliderInput({
path: 'lineWidth',
description: 'Width of the line in pixels',
defaultValue: defaultFieldConfig.lineWidth,
settings: {
min: 0,
max: 10,
step: 1,
.addSliderInput({
path: 'fillOpacity',
name: 'Fill opacity',
description: 'Opacity of the area fill below the line',
defaultValue: defaultFieldConfig.fillOpacity,
settings: {
min: 0,
max: 100,
step: 1,
.addBooleanSwitch({
path: 'showPoints',
description: 'Whether to show data points on the line',
defaultValue: defaultFieldConfig.showPoints,
The builder provides the following methods. All return the builder instance, so you can chain calls:
| Method | Value type | Use case |
addNumberInput | number | Free-form number input |
addSliderInput | number | Number input with a slider |
addTextInput | string | Free-form text input |
addBooleanSwitch | boolean | Toggle switch |
addSelect | T | Dropdown select |
addRadio | T | Radio button group |
addColorPicker | string | Color picker |
addUnitPicker | string | Unit picker dropdown |
addFieldNamePicker | string | Field name picker |
addCustomEditor | T | Fully custom React editor component |
Add a custom editor​
If none of the built-in editors fit your needs, you can build a fully custom editor component using addCustomEditor. For more information on building custom editors, refer to Build a custom panel option editor.
When using addCustomEditor for a field config property, you must also provide an override component (used in the overrides UI) and a process function. For most cases, use identityOverrideProcessor from @grafana/data, which passes the value through unchanged:
import { identityOverrideProcessor } from '@grafana/data';
import { MyCustomEditor } from './MyCustomEditor';
builder.addCustomEditor({
path: 'myProperty',
name: 'My property',
defaultValue: { mode: 'default' },
editor: MyCustomEditor,
override: MyCustomEditor,
process: identityOverrideProcessor,
shouldApply: () => true,
Control property visibility​
Each property config object accepts several optional fields that control when and where the property appears:
category: Groups related properties into a collapsible section in the panel editor. The first array element becomes the section heading.showIf: Shows the property only when a condition is met. Receives the current field config and returns a boolean.shouldApply: Controls whether the property's default value is applied to a given field. Receives the field and returns a boolean. Use it to keep defaults from being applied to fields where they don't make sense, for example numeric styling on string fields. Values set through override rules are applied regardless ofshouldApply.hideFromDefaults: Hides the property from the defaults tab. It remains available in overrides.hideFromOverrides: Hides the property from the overrides tab. It remains available in defaults.
The following example demonstrates category, showIf, and shouldApply together:
import { FieldType, PanelPlugin } from '@grafana/data';
import { FieldConfig, Options } from './types';
builder
.addRadio({
path: 'drawStyle',
category: ['Graph styles'],
defaultValue: 'line',
settings: {
options: [
{ value: 'line', label: 'Line' },
{ value: 'bars', label: 'Bars' },
{ value: 'points', label: 'Points' },
// Only apply the default value to numeric fields
shouldApply: (field) => field.type === FieldType.number,
.addSliderInput({
path: 'lineWidth',
defaultValue: 1,
settings: { min: 0, max: 10, step: 1 },
// Only visible when draw style is "line"
showIf: (config) => config.drawStyle === 'line',
Access field configuration in your panel component​
Grafana applies both defaults and overrides to each field before passing data to your panel. The resolved configuration is available on each field through field.config, with custom properties under field.config.custom:
import React from 'react';
import { FieldType, PanelProps } from '@grafana/data';
import { Options, FieldConfig } from './types';
export const SimplePanel = ({ data, width, height }: PanelProps<Options>) => {
const frame = data.series[0];
return (
<div style={{ width, height }}>
{frame.fields
.filter((field) => field.type === FieldType.number)
.map((field, i) => {
// Standard field config
const unit = field.config.unit;
const decimals = field.config.decimals;
// Custom field config
const custom = (field.config.custom ?? {}) as FieldConfig;
const lineWidth = custom.lineWidth ?? 1;
return (
<span key={i}>
{field.display!(field.values[0]).text} ({unit}, {decimals} decimals, {lineWidth}px line)
</span>
</div>
Complete example​
Here is a complete module.ts that combines standard option customization, disabled options, and custom field configuration properties:
export interface Options {
showLegend: boolean;
lineWidth: number;
drawStyle: 'line' | 'bars' | 'points';
lineWidth: 1,
fillOpacity: 10,
drawStyle: 'line',
.useFieldConfig({
standardOptions: {
settings: {
defaultValue: {
defaultValue: 'short',
disableStandardOptions: [FieldConfigProperty.Mappings],
builder
.addRadio({
path: 'drawStyle',
defaultValue: defaultFieldConfig.drawStyle,
settings: {
options: [
.addSliderInput({
path: 'lineWidth',
settings: {
min: 0,
max: 10,
step: 1,
.addSliderInput({
settings: {
min: 0,
max: 100,
step: 1,
.setPanelOptions((builder) => {
builder.addBooleanSwitch({
path: 'showLegend',
defaultValue: true,
With this setup, dashboard users can set a default draw style, line width, and fill opacity for all fields, and add override rules to change any of these properties for specific fields. For example, they could render one series as bars while keeping the rest as lines.
