# Add query editor help
Query editors support the addition of a help component to display examples of potential queries. When the user clicks on one of the examples, the query editor is automatically updated. This helps the user to make faster queries.
1. In the `src` directory of your plugin, create a file `QueryEditorHelp.tsx` with the following content:
   ```ts
   import React from 'react';
   import { QueryEditorHelpProps } from '@grafana/data';
   export default (props: QueryEditorHelpProps) => {
     return <h2>My cheat sheet</h2>;
2. Configure the plugin to use `QueryEditorHelp`:
   ```ts
   import QueryEditorHelp from './QueryEditorHelp';
   ```ts
   export const plugin = new DataSourcePlugin<DataSource, MyQuery, MyDataSourceOptions>(DataSource)
     .setConfigEditor(ConfigEditor)
     .setQueryEditor(QueryEditor)
     .setQueryEditorHelp(QueryEditorHelp);
3. Create a few examples of potential queries:
   ```tsx
   import { QueryEditorHelpProps, DataQuery } from '@grafana/data';
   const examples = [
       title: 'Addition',
       expression: '1 + 2',
       label: 'Add two integers',
       title: 'Subtraction',
       expression: '2 - 1',
       label: 'Subtract an integer from another',
     return (
       <div>
         <h2>Cheat Sheet</h2>
         {examples.map((item, index) => (
           <div className="cheat-sheet-item" key={index}>
             <div className="cheat-sheet-item__title">{item.title}</div>
             {item.expression ? (
               <div
                 className="cheat-sheet-item__example"
                 onClick={(e) => props.onClickExample({ refId: 'A', queryText: item.expression } as DataQuery)}
                 <code>{item.expression}</code>
               </div>
             ) : null}
             <div className="cheat-sheet-item__label">{item.label}</div>
           </div>
       </div>
