Add default variables and links
This feature is available from Grafana 13.0 and later.
Data source plugins can register default variables and dashboard links that are automatically loaded onto any dashboard using that data source. This is useful when your data source requires certain filter variables or benefits from having quick-access links to external documentation or related tools.
Before you begin​
Ensure your development environment meets the following prerequisites:
- Grafana version: Grafana 13.0 or later.
@grafana/data: Version 13.0.0 or later.@grafana/schema: Version 13.0.0 or later.
Key behaviors​
- Not persisted. Default variables and links are loaded at dashboard load time. They are not saved as part of the dashboard model.
- URL sync. Default variables appear in the URL as query parameters, so shared dashboard links preserve the selected values.
- Read-only. Default variables and links are displayed as read-only in the dashboard settings views. Users cannot edit or remove them from the dashboard.
- Name prefixing. Grafana automatically prefixes default variable names with the data source plugin ID to prevent collisions with user-defined template variables. For example, a variable named
environmentfrom aprometheusdata source becomesprometheus_environmentin the URL. The originalnameis used as the display label if nolabelis provided.
Add default variables​
Implement the optional getDefaultVariables method on your DataSourceApi class to return an array of VariableKind objects using the v2 dashboard schema. Set hide to 'inControlsMenu' so that default variables appear in the dashboard controls menu rather than the main variable bar:
import { DataSourceApi, DataSourceInstanceSettings } from '@grafana/data';
import { VariableKind, DashboardLink } from '@grafana/schema/apis/dashboard.grafana.app/v2';
import { MyQuery, MyDataSourceOptions } from './types';
export class DataSource extends DataSourceApi<MyQuery, MyDataSourceOptions> {
constructor(instanceSettings: DataSourceInstanceSettings<MyDataSourceOptions>) {
super(instanceSettings);
async getDefaultVariables(): Promise<VariableKind[]> {
return [
kind: 'CustomVariable',
spec: {
label: 'Environment',
query: 'production,staging,development',
current: {
value: 'production',
text: 'Production',
options: [
{ value: 'production', text: 'Production' },
{ value: 'staging', text: 'Staging' },
{ value: 'development', text: 'Development' },
allowCustomValue: false,
skipUrlSync: false,
hide: 'inControlsMenu',
multi: false,
// ... other methods
Add default dashboard links​
Implement the optional getDefaultLinks method on your DataSourceApi class to return an array of DashboardLink objects. Set placement to 'inControlsMenu' so that default links appear in the dashboard controls menu:
async getDefaultLinks(): Promise<DashboardLink[]> {
return [
title: 'Documentation',
type: 'link',
url: 'https://example.com/docs',
tooltip: '',
targetBlank: true,
icon: 'doc',
tags: [],
asDropdown: false,
includeVars: false,
keepTime: false,
placement: 'inControlsMenu',
