Select language
Grafana v6.0 Released
2019-02-25 8 min
##v6.0 Stable released!
GrafanaCon LA is underway! Check out the live stream on the Grafana youtube channel. I am proud to announce that we are releasing Grafana v6.0 stable today. Before every major release I feel super excited about the progress that has been made and with this release, this is especially true.
Grafana v6.0 brings many new and exciting features and enhancements and at the same time includes a new React platform and architecture for panels & plugins that will fundamentally change Grafana’s future as a platform.
What’s New in Grafana v6.0
Download Grafana 6.0 Now
Explore
Screenshot of the new Explore option in the panel menu
Grafana’s dashboard UI is all about building dashboards for visualization. Explore strips away all the dashboard and panel options so that you can focus on the query & metric exploration. Iterate until you have a working query and then think about building a dashboard. You can also jump from a dashboard panel into Explore and from there do some ad-hoc query exporation with the panel queries as a starting point.
For infrastructure monitoring and incident response, you no longer need to switch to other tools to debug what went wrong. Explore allows you to dig deeper into your metrics and logs to find the cause. Grafana’s new logging datasource, Loki is tightly integrated into Explore and allows you to correlate metrics and logs by viewing them side-by-side.
Explore is a new paradigm for Grafana. It creates a new interactive debugging workflow that integrates two pillars of observability - metrics and logs. Explore works with every datasource but for Prometheus we have customized the query editor and the experience to provide the best possible exploration UX.
Explore and Prometheus
Explore features a new Prometheus query editor. This new editor has improved autocomplete, metric tree selector, integrations with the Explore table view for easy label filtering and useful query hints that can automatically apply functions to your query. There is also integration between Prometheus and Grafana Loki (see more about Loki below) that enabled jumping between metrics query and logs query with preserved label filters.
Explore splits
Explore supports splitting the view so you can compare different queries, different datasources and metrics & logs side by side!
Explore and Grafana Loki
The log exploration & visualization features in Explore are available to any data source but are currently only implemented by the new open source log aggregation system from Grafana Lab called Grafana Loki.
Loki is a horizontally-scalable, highly-available, multi-tenant log aggregation system inspired by Prometheus. It is designed to be very cost effective, as it does not index the contents of the logs, but rather a set of labels for each log stream. The logs from Loki are queried in a similar way to querying with label selectors in Prometheus. It uses labels to group log streams which can be made to match up with your Prometheus labels.
Read more about Grafana Loki here or Grafana Labs hosted Loki.
The Explore feature allows you to query logs and features a new log panel. In the near future, we will be adding support for other log sources to Explore and the next planned integration is Elasticsearch.
New Panel Editor
Grafana v6.0 has a completely redesigned UX around editing panels. You can now resize the visualization area if you want more space for queries & options and vice versa. You can now also change visualization (panel type) from within the new panel edit mode. No need to add a new panel to try out different visualizations! Check out the video below to see the new Panel Editor in action.
Gauge Panel
We have created a new separate Gauge panel as we felt having this visualization be a hidden option in the Singlestat panel was not ideal. When it supports 100% of the Singlestat Gauge features we plan to add a migration so all singlestats that use it become Gauge panels instead. This new panel contains a new Threshold editor that we will continue to refine and start using in other panels.
Gauge Panel
Gauge Panel
React Panels & Query Editors
A major part of all the work that has gone into Grafana v6.0 has been on the migration to React. This investment is part of the future proofing of Grafana’s code base and ecosystem. Starting in v6.0 Panels and Data source plugins can be written in React using our published @grafana/ui sdk library. More information on this will be shared soon.
React Panel
React Panel
Google Stackdriver Datasource
Built-in support for Google Stackdriver is officially released in Grafana 6.0. Beta support was added in Grafana 5.3 and we have added lots of improvements since then.
To get started read the guide: Using Google Stackdriver in Grafana.
Azure Monitor Datasource
One of the goals of the Grafana v6.0 release is to add support for the three major clouds. Amazon Cloudwatch has been a core datasource for years and Google Stackdriver is also now supported. We developed an external plugin for Azure Monitor last year and for this release the plugin is being moved into Grafana to be one of the built-in datasources. For users of the external plugin, Grafana will automatically start using the built-in version. As a core datasource, the Azure Monitor datasource is able to get alerting support, in the 6.0 release alerting is supported for the Azure Monitor service, with the rest to follow.
The Azure Monitor datasource integrates four Azure services with Grafana - Azure Monitor, Azure Log Analytics, Azure Application Insights and Azure Application Insights Analytics.
Provisioning support for alert notifiers
Grafana now added support for provisioning alert notifiers from configuration files. Allowing operators to provision notifiers without using the UI or the API. A new field called uid has been introduced which is a string identifier that the administrator can set themselves. Same kind of identifier used for dashboards since v5.0. This feature makes it possible to use the same notifier configuration in multiple environments and refer to notifiers in dashboard json by a string identifier instead of the numeric id which depends on insert order and how many notifiers that exists in the instance.
Easier to deploy & improved security
Grafana 6.0 removes the need of configuring and setup of additional storage for user sessions. This should make it easier to deploy and operate Grafana in a high availability setup and/or if you’re using a stateless user session storage like Redis, Memcache, Postgres or MySQL.
Instead of user sessions a solution based on short-lived tokens that are rotated frequently have been implemented. This also replaces the old “remember me cookie” solution, which allowed a user to be logged in between browser sessions, and which have been subject to several security holes throughout the years. Read more about the short-lived token solution and how to configure it here.
Please note that due to these changes, all users will be required to login upon next visit after upgrade.
Besides these changes we have also made security improvements regarding Cross-Site Request Forgery (CSRF) and Cross-site Scripting (XSS) vulnerabilities:
  • Cookies are per default using the SameSite attribute to protect against CSRF attacks
  • Script tags in text panels are per default disabled to protect against XSS attacks
If you’re using Auth Proxy Authentication you still need to have user sessions setup and configured but our goal is to remove this requirements in a near future.
Named Colors
Named Colors
Named Colors
We have updated the color picker to show named colors and primary colors. We hope this will improve accessibility and helps making colors more consistent across dashboards. We hope to do more in this color picker in the future, like show colors used in the dashboard.
Named colors also enables Grafana to adapt colors to the current theme.
Other features
  • The ElasticSearch datasource now supports bucket script pipeline aggregations. This gives the ability to do per bucket computations like the difference or ratio between two metrics.
  • Support for Google Hangouts Chat alert notifications
  • New built in template variables for the current time range in $__from and $__to
Upgrading
See upgrade notes.
Changelog
Check out the CHANGELOG.md file for a complete list of new features, changes, and bug fixes.
Download
Head to download page for download links & instructions.
Thanks
A big thanks to all the Grafana users who contribute by submitting PRs, bug reports & feedback!
