Select language
timeShift(GrafanaBuzz, 1w) Issue 53
2018-07-20 5 min
Welcome to TimeShift
This week we’re showing off 2 more brand-new plugins, plus a case study showing how PingCAP troubleshoots more than a thousand metrics from their TiDB clusters. Also, Tweet of the Week returns with a graph celebrating France’s World Cup victory. Enjoy!
Have an article you’d like included in an upcoming TimeShift? Contact Us.
Latest Stable Release: Grafana 5.2.1
New Features
See everything new in Grafana v5.2.1.
Download Grafana 5.2.1 Now
From the Blogosphere
How Grafana Helps PingCAP Troubleshoot TiDB Deployments: A case study on how PingCAP diagnoses and troubleshoots issues from a thousand metrics on their open source TiDB clusters using Grafana.
Azure Log into Grafana using Stream Analytics jobs: Learn how to export data using Azure Stream Analytics jobs in Azure SQL and visualize the data in Grafana.
How to Monitor ArangoDB using collectd, Prometheus and Grafana: The folks from ArangoDB have put together a tutorial on how to install, configure and visualize metrics for ArangoDB.
Room temperature monitoring with Philips Hue, Node-RED and Grafana: This how-to guide explains how to use a Philips Hue Smart Home lighting system to measure the temperature in a room and visualize the data in a Grafana Dashboard.
Visualizing Data using Grafana: We’ve seen an explosion of interest in using Grafana to visualize data for home automation. This tutorial shows you how to install and run Grafana on a Raspberry Pi with InfluxDB, and Home Assistant.
Grafana Plugins
This week we have an update to the Clickhouse data source and 2 new plugins to share. Depending on your installation, there are 2 ways to update plugins – for on-prem Grafana, use the grafana-cli tool, or for Hosted Grafana update with one-click.
NEW PLUGIN
Akumuli Data source - The Akumuli timeseries database now has a published Grafana datasource plugin. It contains a full-featured query editor and supports templating.
Install
NEW PLUGIN
TrafficLight Panel - A new status panel with traffic lights has been published. The TrafficLight Panel allows you to add a traffic light per query and place it on an image background.
Install
UPDATED PLUGIN
Clickhouse Data source - Added a performance improvement that optimizes memory use for range time series. See this PR for more details.
Install
Tweet of the Week
We scour Twitter each week to find an interesting/beautiful dashboard or monitoring related tweet and show it off! #monitoringLove
Laissez le bon temps rouler!
We're Hiring!
We're looking for passionate and talented engineers for positions in New York/Stockholm and remote! Do you love open source software? Do you thrive on tackling complex challenges to build the future? Want to work with awesome people? Be the next to join our team!
View our Open Positions
Upcoming Events
In between code pushes we like to speak at, sponsor and attend all kinds of conferences and meetups. We also like to make sure we mention other Grafana-related events happening all over the world. If you’re putting on just such an event, let us know and we’ll list it here.
PromCon 2018 | Munich, Germany - August 9-10, 2018:
Tom Wilkie: [Prometheus](/oss/prometheus/) Monitoring Mixins: Using Jsonnet to Package Together Dashboards, Alerts, and Exporters - Prometheus offers powerful open source monitoring and alerting - but that comes with higher degrees of freedom, making pre-configured monitoring "packages" hard to build. Simultaneously, it's becoming accepted wisdom that the developers of a given software package are best placed to operate said software, or at least construct the basic monitoring configuration.
In this talk we present a technique for using Jsonnet (a configuration language from Google) for packaging and deploying "Monitoring Mixins" - extensible and customisable combinations of dashboards, alert definitions and exporters. This technique allows developers of open source projects to publish best-practice monitoring configurations alongside their code, and for users to consume it, customise it and stay up to date. We will present example Mixins for Kubernetes and other services such as Consul, Vault, and Cassandra.
David Kaltschmidt: Explore Your Prometheus Data in Grafana – Grafana is the de-facto dashboarding solution for Prometheus. Now imagine you received a page. Grafana is often the starting point for your incident response. You look at a time series panel, form a hypothesis, and would like to dive deeper. We've built a whole new section that allows you to do just that by iterating quickly through Prometheus queries while leaving your dashboards intact. I'll show-case our new Explore UI and how it can fit into your workflows for both troubleshooting and data exploration.
We're also a proud PromCon 2018 sponsor of the evening social event and a diversity scholarship. We hope to see you there!
Register Now
2018 Sensu Summit | Portland, OR - August 22-23, 2018:
We are a proud sponsor of this year's Sensu Summit! Come enjoy Portland in the summer and learn a ton from the sharpest operations engineers in monitoring!
More Info
CloudNative London 2018 | London, United Kingdom - September 26-28, 2018:
Tom Wilkie: Monitoring Kubernetes With Prometheus – In this talk Tom will explore all the moving part for a working Prometheus-on-Kubernetes monitoring system, including kube-state-metrics, node-exporter, cAdvisor and Grafana. You will learn about the various methods for getting to a working setup: the manual approach, using CoreOS's Prometheus Operator, or using Prometheus Ksonnet Mixin.
Tom will also share some little tips and tricks for getting the most out of your Prometheus monitoring, including the common pitfalls and what you should be alerting on.
Register Now
How are we doing?
Hope you enjoyed this issue of TimeShift. What do you think? Are there other types of content you’d like to see here? Submit a comment on this issue below, or post something at our community forum.
Follow us on Twitter, like us on Facebook, and join the Grafana Labs community.
