Select language
timeShift(GrafanaBuzz, 1w) Issue 10
2017-08-25 4 min
This week, in addition to the articles we collected from around the web and a number of new Plugins and updates, we have a special announcement. GrafanaCon EU has been announced! Join us in Amsterdam March 1-2, 2018. The call for papers is officially open! We’ll keep you up to date as we fill in the details.
Grafana <3 Prometheus
Last week we mentioned that our colleague Carl Bergquist spoke at PromCon 2017 in Munich. His presentation is now available online. We will post the video once it’s available.
From the Blogosphere
Grafana-based GUI for mgstat, a system monitoring tool for InterSystems Caché, Ensemble or HealthShare: This is the second article in a series about Making Prometheus Monitoring for InterSystems Caché. Mikhail goes into great detail about setting this up on Docker, configuring the first dashboard, and adding templating.
Installation and Integration of Grafana in Zabbix 3.x: Daniel put together an installation guide to get Grafana to display metrics from Zabbix, which utilizes the Zabbix Plugin developed by Grafana Labs Developer Alex Zobnin.
Visualize with RRDtool x Grafana: Atfujiwara wanted to update his MRTG graphs from RRDtool. This post talks about the components needed and how he connected RRDtool to Grafana.
Huawei OceanStor metrics in Grafana: Dennis is using Grafana to display metrics for his storage devices. In this post he walks you through the setup and provides a comprehensive dashboard for all the metrics.
Grafana on a Raspberry Pi2: Pete discusses how he uses Grafana with his garden sensors, and walks you through how to get it up and running on a Pi2.
Grafana Plugins
This week was pretty active on the plugin front. Today we’re announcing two brand new plugins and updates to three others. Installing plugins in Grafana is easy – if you have Hosted Grafana, simply use the one-click install, if you’re using an on-prem instance you can use the Grafana-cli.
NEW PLUGIN
IBM APM Data Source - This plugin collects metrics from the IBM APM (Application Performance Management) products and allows you to visualize it on Grafana dashboards. The plugin supports:
  • IBM Tivoli Monitoring 6.x
  • IBM SmartCloud Application Performance Management 7.x
  • IBM Performance Management 8.x (only on-premises version)
Install Now
NEW PLUGIN
Skydive Data Source - This data source plugin collects metrics from Skydive, an open source real-time network topology and protocols analyzer. Using the Skydive Gremlin query language, you can fetch metrics for flows in your network.
		</p>
		<p>
			<a class="btn btn-outline btn-small" href="https://grafana.com/plugins/skydive-datasource?utm_source=blog&utm_campaign=timeshift_10" target="_blank"><strong>Install now</strong></a>
		</p>
	</div>
</div>
UPDATED PLUGIN
Datatable Panel - Lots of changes in the latest update to the Datatable Panel Here are some highlights from the changelog:
  • NEW: Export options for Clipboard/CSV/PDF/Excel/Print
  • NEW: Column Aliasing - modify the name of a column as sent by the datasource
  • NEW: Added option for a cell or row to link to another page
  • NEW: Supports Clickable links inside table
  • BUGFIX: CSS files now load when Grafana has a subpath
  • NEW: Added multi-column sorting - sort by any number of columns ascending/descending
  • NEW: Column width hints - suggest a width for a named column
  • BUGFIX: Columns from datasources other than JSON can now be aliased
Update Now
UPDATED PLUGIN
D3 Gauge Panel - The D3 Gauge Panel has a new feature - Tick Mapping. Ticks on the gauge can now be mapped to text.
Update Now
UPDATED PLUGIN
PNP4Nagios Data Source - The most recent update to the PNP Data Source adds support for template variables in queries and as well as support for querying warning and critical thresholds.
Update Now
This week's MVC (Most Valuable Contributor)
Each week we highlight a contributor to Grafana or the surrounding ecosystem as a thank you for their participation in making open source software great.
Brian Gann
Brian is the maintainer of two Grafana Plugins and this week he submitted substantial updates to both of them (Datatable and D3 Gauge panel plugins); and he says there's more to come! Thanks for all your hard work, Brian.
#### Tweet of the Week We scour Twitter each week to find an interesting/beautiful dashboard and show it off! #monitoringLove
The Dark Knight popping up in graphs seems to be a recurring theme!
This is the graph Jakub deserves, but not the one he needs right now.
#### What do you think? That's it for the 10th issue of timeShift. Let us know how we're doing! Submit a comment on this article below, or post something at our [community forum](https://community.grafana.com?utm_source=blog&utm_campaign=timeshift_10). Help us make this better!
Follow us on Twitter, like us on Facebook, and join the Grafana Labs community.
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
