Select language
Grafana 4.2 Release
Grafana 4.2 Release
2017-03-22 3 min
Grafana v4.2 Stable is now available for download. Just like the last release this one contains lots bug fixes and minor improvements. We are very happy to say that 41 of 53 issues was closed by pull requests from the community. Big thumbs up!
Release Highlights
  • Hipchat: Adds support for sending alert notifications to hipchat #6451, thx @jregovic
  • Telegram: Added Telegram alert notifier #7098, thx @leonoff
  • LINE: Add LINE as alerting notification channel #7301, thx @huydx
  • Templating: Make $__interval and $__interval_ms global built in variables that can be used in by any datasource (in panel queries), closes #7190, closes #6582
  • Alerting: Adds deduping of alert notifications #7632
  • Alerting: Better information about why an alert triggered #7035
  • Orgs: Sharing dashboards using Grafana share feature will now redirect to correct org. #6948
  • Full changelog
New alert notification channels
This release adds five new alert notifications channels, all of them contributed by the community.
  • Hipchat
  • Telegram
  • LINE
  • Pushover
  • Threema
Templating
We added two new global built in variables in grafana. $__interval and $__interval_ms are now reserved template names in grafana and can be used by any datasource. We might add more global built in variables in the future and if we do we will prefix them with $__. So please avoid using that in your template variables.
Dedupe alert notifications when running multiple servers
In this release we will dedupe alert notificiations when you are running multiple servers. This makes it possible to run alerting on multiple servers and only get one notification.
We currently solve this with sql transactions which puts some limitations for how many servers you can use to execute the same rules. 3-5 servers should not be a problem but as always, it depends on how many alerts you have and how frequently they execute.
Next up for a better HA situation is to add support for workload balancing between Grafana servers.
Alerting more info
You can now see the reason why an alert triggered in the alert history. Its also easier to detect when an alert is set to alerting due to the no_data option.
Improved support for multi-org setup
When loading dashboards we now set an query parameter called orgId. So we can detect from which org an user shared a dashboard. This makes it possible for users to share dashboards between orgs without changing org first.
We aim to introduce dashboard groups sometime in the future which will introduce access control and user groups within one org. Making it possible to have users in multiple groups and have detailed access control.
Upgrade & Breaking changes
If your using https in grafana we now force you to use tls 1.2 and the most secure ciphers. We think its better to be secure by default rather then making it configurable. If you want to run https with lower versions of tls we suggest you put a reserve proxy in front of grafana.
If you have template variables name $__interval or $__interval_ms they will no longer work since these keywords are reserved as global built in variables. We might add more global built in variables in the future and if we do, we will prefix them with $__. So please avoid using that in your template variables.
Changelog
Checkout the CHANGELOG.md file for a complete list of new features, changes, and bug fixes.
Download
Head to v4.2 download page for download links & instructions.
Thanks
A big thanks to all the Grafana users who contribute by submitting PRs, bug reports & feedback!
