Menu
DocumentationGrafana documentationPanelsCreate reusable Grafana panelsCreate a Grafana library panel
Enterprise
When you create a library panel, the panel on the source dashboard is converted to a library panel as well. You need to save the original dashboard once a panel is converted.
Before you begin
To create a library panel:
- Open a panel in edit mode.
- In the panel display options, click the down arrow option to bring changes to the visualization.
- Click the Library panels option, and then click Create new library panel to open the create dialog.
- In Library panel name, enter the name.
- In Save in folder, select the folder to save the library panel.
- Click Create library panel to save your changes.
- Save the dashboard.
Once created, you can modify the library panel using any dashboard on which it appears. After you save the changes, all instances of the library panel reflect these modifications.
Was this page helpful?
Related documentation
Video
Getting started with the Grafana LGTM Stack
In this webinar, we’ll demo how to get started using the LGTM Stack: Loki for logs, Grafana for visualization, Tempo for traces, and Mimir for metrics.
Video
Getting started with Grafana dashboard design
In this webinar, you'll learn how to design stylish and easily accessible Grafana dashboards that tell a story.
Video
Building advanced Grafana dashboards
In this webinar, we’ll demo how to build and format Grafana dashboards.
