Plugins 〉Splunk
Splunk
Instantly visualize Splunk data in Grafana
The Splunk data source plugin is the easiest way to pull Splunk data directly into Grafana dashboards.
- Visualize it either in isolation (one database) or blend it with other data sources.
- Discover correlations and covariances across all your data in minutes.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Splunk on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Splunk from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Change Log
v4.8.0 - 2024-05-29
- ⚙️ Chore: update backend dependencies
v4.7.0 - 2024-05-22
- ⚙️ Chore: Refactor the config page
- ⚙️ Chore: Update backend libraries
v4.6.2 - 2024-03-13
- ⚙️ Chore: Backend binaries are now compiled with Go version
1.22.1
v4.6.1 - 2024-01-25
- 🐛 Fix: Fix authentication error
v4.6.0 - 2024-01-17
- ⚙️ Chore: Return error source with query errors
v4.5.2 - 2023-12-18
- 🐛 Fix: Fix for rendering public dashboards
v4.5.1 - 2023-12-13
- 🐛 Fix: Fix sharing public dashboards
v4.5.0 - 2023-12-06
- ⚙️ Chore: Update backend and frontend packages
v4.4.0 - 2023-11-03
- ⚙️ Chore: Fix security vulnerabilities
v4.3.4 - 2023-10-20
- 📝 Documentation: Update online docs
v4.3.3 - 2023-09-19
- ⚙️ Chore: migrate to create-plugin
v4.3.2 - 2023-08-17
- ⚙️ Chore: Backend binaries are now compiled with Go version 1.21
v4.3.1 - 2023-08-10
- ⚙️ Chore: update dependencies
v4.3.0 - 2023-06-13
- 🚀 Feature: Added support for configuring global result limit
v4.2.2 - 2023-06-12
- 🐛 Fix: only fetch suggestions for non-empty queries
v4.2.1 - 2023-06-08
- ⚙️ Chore: backend libs updated with golang:1.20.5
v4.2.0 - 2023-05-24
- Update the UI of the config page and clean up the documentation
v4.1.10 - 2023-05-17
- Prevent unnecessary query run when query editor is rendered
v4.1.9 - 2023-05-04
- 🐛 Fix: Fixed issue with "No data" returned when "Poll result" or "Preview mode" were enabled
v4.1.8 - 2023-05-03
- ⚙️ Chore: Backend binaries are now compiled with golang 1.20.4
v4.1.7 - 2023-04-14
- 🐛 Fix: Fixed a bug where annotation queries didn't pass the namespace value
- ⚙️ Chore: Backend binaries are now compiled with golang 1.20.3
v4.1.6 - 2023-03-13
- 🐛 Fix: Fixed a "Data source not found" error
v4.1.5 - 2023-03-10
- 🐛 Fix: Fixed a bug when request errors were not shown on the panel
v4.1.4 - 2023-03-08
- 🐛 Fix: Fixed a bug when plugin was producing errors when requesting a big amount of data
v4.1.3 - 2023-02-24
- 🐛 Fix: Fixed a bug where the plugin failed to execute queries in Grafana version 9.4.0 and above
v4.1.2 - 2023-02-22
- 🐛 Fix: Fix query request using old datasource string format
v4.1.1 - 2023-02-21
- Fixed issue with appending nil frame
v4.1.0 - 2023-01-04
- Fixed wrong color theme on annotation editor input fields
- Migrate angular annotation editor to react
v4.0.6 - 2022-12-15
⚙️ Chore: Backend binaries are now compiled with the latest go version (1.19.4)
⚙️ Chore: Grafana dependencies are updated to latest version
⚙️ Chore: Add spellcheck + fix typos
Updated datasource instance init
v4.0.5 - 2022-10-28
- Updated datasource instance init
v4.0.4 - 2022-10-28
- Updated postman collection and contributing guide how to use
v4.0.3 - 2022-09-22
- Fixed a bug where the first time loading a query would sometimes error. This was due to a sending a nil response to httputil.DumpResponse
v4.0.2 - 2022-09-21
- Fixed a bug where health check was failing due to incorrect response format
v4.0.1 - 2022-08-25
- Enhanced request and response debug logging
v4.0.0 - 2022-07-12
- Token authentication method added
- BREAKING CHANGE: Session key clustering strategy / authentication method removed
v3.1.0-beta.1 - 2022-06-12
- Added support for HTTP logger
- Added support for multiple data links
v3.0.2 - 2022-04-20
- Handle null namespace values
v3.0.1 - 2022-03-29
- New builds with go 1.18 to address CVE-2022-24921
v3.0.0 - 2021-01-18
- Minimum supported Grafana version is now set to v8.2.0
- Support sample ratio in explore view URLs
- Fixes an issue with data link support in dashboard panels
v2.2.3 - 2021-12-17
- Enterprise license check update
v2.2.2 - 2021-12-14
- Values for template variables can now be numbers.
v2.2.1 - 2021-11-23
- Fixed an issue with escaping wildcards in queries with template variables
- Fixed an issue with applying defaults for Preview Mode and event sampling
v2.2.0 - 2021-11-01
- Added support for multi-value fields
- Added support for event sampling
- Added support for navigating from Prometheus metrics to Splunk logs in Explore
- Renamed Stream Mode to Preview Mode
- Fixed an issue with Preview Mode that prevented the display of partial results
- Prevent internal field filters from being applied to dashboard variable queries
- Improved query processing performance by 38 percent and reduced memory usage by 50 percent
- Fixed invalid output in
mstats
queries
v2.1.7 - 2021-09-08
- Fixed issue that would filter internal fields even if internal field filtering was disabled
v2.1.6 - 2021-08-04
- Documentation update
v2.1.5 - 2021-07-30
- Fixed issue where alerting queries don't filter out internal fields
- Results that return data in multiple different types are typed as string
v2.1.4 - 2021-06-02
Bug Fixes
- #278: 'No data' displayed for Grafana 8
v2.1.3 - 2021-05-27
Bug Fixes
- #265: Errors returned when in polling mode cause the driver to crash
- #226: Filter fields prefixed with _ if filtration is on
v2.1.2 - 2021-04-12
- ⚙️ Chore: Update SDK
v2.1.1 - 2020-04-06
Bug Fixes
- #254: To template variables properly, splunk should be passing in scopedvars into the templating engine
- #224: Splunk executes queries that have hide = true (the eye icon)
- #222: Get the splunk changelog to publish to GCOM by upgrading to the "next" toolkit"
- #246: Splunk should not refresh the query immediately after every pause in typing/editing the query
- #239: Enable E2E tests
- #215: "Skip TLS Verify" option not working
- #213: "Post forbidden" error after upgrading to 2.0.4
- #208: Update to new SDK to support individual plugin licensing
v2.1.0 - 2020-01-25
Bug fixes
- #212: Return all indexes
- #235: Better handle edge cases
- #236: Better handle an out-of-bounds error
Enhancements
- #187: Update README
- #210: Link from logs to traces using data links or derived fields
Known issues
- You must use
around regular expressions in the datalinks configuration or any plugin health check will fail. When a regular expression is optional, use an empty//
v2.0.5 - 2020-12-11
Bug fixes
- #214: Time filters not working for Splunk queries in dashboard variables
- #210,#209: Plugin crashes a lot while trying out queries
v2.0.4 - 2020-10-27
- 🐛 Fix: If session key is empty, still valid
- Enhancement: When using splunk in clustered mode, allow user to revert to 'basic auth'
v2.0.3 - 2020-10-19
- 🐛 Fix: Fix for proxy settings, now will recognize standard "http_proxy" "https_proxy" and "no_proxy" environment variables
- TLS Skip Verification now performs verification when not checked
v2.0.2 - 2020-09-10
- 🐛 Fix: Fix for time range issue #184
v2.0.1 - 2020-06-01
Issues Resolved
v2.0.0 - 2020-05-22
- Rewritten as a backend plugin with native alerting support
- Removed distinction between table & time_series results
- Signed version for grafana 7.x
v1.5.0 - 2020-05-17
- Signed release for Grafana 7.x
v1.4.1 - 2020-01-10
Fixed
- "Unbalanced quotes" error when using variables in some scenarios
- Logs panel does not show data in logs format
- Query returns only first 100 points
v1.4.0 - 2019-11-26
Added
- Explore logs integration
v1.3.4 - 2019-11-22
Fixed
- Plugin failed with "Unexpected token <" error
v1.3.3 - 2019-11-21
Fixed
- Query in template variable with no result data is running forever #82
v1.3.2 - 2019-10-03
Fixed
- Plugin failed in Grafana 6.4 with error "Unexpected token <"
v1.3.1 - 2019-10-01
Fixed
- Streaming support in Grafana 6.4 (incompatible with previous version)
v1.3.0 - 2019-07-30
Added
- Variable query editor with namespace support, #63
Fixed
- Streaming support in Grafana 6.3
v1.2.2 - 2019-06-29
Fixed
- Bug with semicolon in query, #57
- Variable expansion when concatenated with literal string, #58
- Variable expansion when there is a period character in the name, #59
v1.2.1 - 2019-03-18
Fixed
v1.2.0 - 2019-02-01
Added
Fixed
- Table panel is empty after update to v1.1.0, #34
- Panel is not refreshing on leaving search field, #40
v1.1.0 - 2018-11-14
Added
- Multi-value template variables support, #2
- Use time range for variable queries if Refresh option set to On Time Range Change
- Option for variables search mode in datasource config (fast/smart/verbose)
